Question about GE Dishwashers
No water on GDT530PSDS GE Dishwasher. Tapped float still no water.
rajak2009
  • 527 Answers
SOURCE: I have a GE GSD1930X66WW dishwasher. The water
Sir,
GE dishwashers will have a sumpentrance screen ( #4 ) that should beremoved and checked for any gookus, see 1 or 2 screws on the cover top, which isbehind the lower spray arm. Almost all ( some newer GE dishwashers have a separatedrain pump and motor - but for our purpose, we will talk about the mostcommon GE dishwashers ) GE dishwashers have a drainsolenoid ( #1 ) that can fail and stopthe draining. If the solenoid cannot pull in the silver plunger, the drain portwill not open to allow the motor and pump assembly to drain the water out. Thesolenoid can be ohmedwith an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GEdishwashers have a selfclean filter ( #3 ) inside at the back.The draining water must pass through a plunger in the self clean filter body.This can get clogged up, or the plunger may twist and distort and not allow thedraining water to get past. The filter can be removed from the inside and theplunger will twist out of the self cleaning body for testing/checking. Next obstaclefor the draining water in the backflush valve ( #2 ). This valve can twistor distort and block the water flow as well. The drain port will need to beaccessed to check this flapper valve, the drain port will untwist from the selfclean filter body. All hoses in-between the items mentioned above and the drainhose itself all the way to the house plumbing should be checked forrestrictions.
click this link for more help
Thanks
Good Luck
Posted on Aug 17, 2009
SOURCE: The start timer control cycles but nothing happens.
I bought a new one and installed it myself. hardest part of installing was taking the old unit out. I compared the cost of a second repair of a 10 year old dishwasher vs. purchasing a new one. We also checked the pump and solenoid to find problems that caused the water not to enter the unit. The new one we purchased is much better, quieter, and Energy Star.
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: no water imput. ge profile
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 07, 2010
MNTECH
  • 1543 Answers
SOURCE: my ge pdw9280j00ss dishwasher won't stop water
Replace the inlet water valve.
techbuster
  • 5081 Answers
SOURCE: dishwasher not getting water water valve is on and
The most possible problem is that the water inlet valve has failed ..
Check this video
Please check the video .
It is quite technical and please don't deny the credit to the expert by voting him low if the answer is valid and cannot be tried at home.
Posted on May 19, 2011
GE dishwasher model number GHDA480N10WW doesn't fill with water.
check the float switch usually located in the front right of the dishwasher it should move up and down freely sometimes crud will get under the float and hold it up so the dishwasher thinks its already full.
Nov 02, 2013 | Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwasher has no water
Find out where your water supply is turned on to your dishwasher. Usually it is under the sink and make sure the valve is turned counter clockwise to supply water to the dishwasher. If this is on, on some models there is a float switch that will sometimes get stuck in the overflow position. Look in the bottom of the dishwasher tub and you will see a round float. Usually it is in the front left of the dishwasher. Move the float up and down and you should hear a clicking noise. Make sure float stays in the lowered position, closest to the dishwasher floor. Check those two and let me know what you find. And we can go from there.
Apr 01, 2012 | GE Dishwashers
No water imput. ge profile dishwasher. PDW9280J00SS. TRIED HITTING THE FLOAT COVER.
heatman101
Sep 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Water will not pump into dishwasher but will pump out
Hello. there are two devices that control the flow of water into a dishwasher. They are the water-inlet valve and the float switch.
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 18, 2009 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher turns on but no water is going into the dishwasher it is a GE potscubber 970
As there is no water entering the machine, check ;-
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
The start timer control cycles but nothing happens. The motor seems to gurgle while attempting to fill with water - but no water comes through. We have had this problem before and the repair person...
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
Water not coming into the dishwasher.
There's no water entering the machine
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck......
Mar 28, 2009 | GE Dishwashers
Dishwashers Logo
81 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
