Question about Kenmore 74602 Gas Dryer
I have a kenmore gas dryer modal # 76722691 76722, it runs but no heat. i did clean exhaust vents. I feel no heat.
  • 999 Answers
Do you hear a snap when it first starts? If yes check the ignitor. If no check the thermal fuse and/or the thermostat.
Eric
Posted on Jun 10, 2009
Kenmore 110.70982990 front loading gas dryer. Everything seems to work, except the flame stays on for only 5-10 seconds, and therefore does not produce enough heat. Lights up again after a few minutes,...
Remove the exhaust vent from the rear and try a load of laundry.
If ir dries correctly,clean and or repair the connecting exhaust vent.
It may also be necessary to disassemble the dryer and clean internal ducts.
Feb 20, 2011 | Kenmore 63942 Dryer
Kenmore gas dryer model 90 110.70912990 does not heat. Exhaust vent is clean.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Kenmore Dryers
Kenmore elite gas dryer will not heat
clean out any lint build up in the exhaust vent tubes
the moister sensor will put the heat in check if clogged up
Aug 01, 2010 | Kenmore 63942 Dryer
Kenmore 77904 doesn't heat
Check the lint build up inside the exhaust vents first and try again
May 09, 2010 | Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
Jun 21, 2009 | Kenmore 73952 Gas Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore 74602 Gas Dryer Logo
286 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
