Question about Cuisinart CBC-00FR 12-Cup Coffee Maker
User manual coffee pot shutting off, how do i reset it
3 Suggested Answers
SOURCE: coffee maker wont stay on after making a pot of coffee help
i downloaded the owners manual at http://www.cuisinartwebstore.com/detail/CUI+DGB-300BK
and resolved it by reading the manual. ( i had lost my original )
Posted on May 17, 2009
  • 85 Answers
SOURCE: Cuisinart coffee pot
Hello YaYa!
If you still have you machine you might try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 06, 2009
BLACK AND DECKER HC100 COFFEE POT
HI,
You will have to contact the main support no.1-800-544-6986 and tell them to email you a copy of user manual to you.
Sep 13, 2008 | Black & Decker HCC100 Coffee Maker
The coffee pot turns itself off immediately after brewing a pot of coffee.
The machine is designed to shut off after the brewing cycle after a period of time which you can manually set anywhere from 0-4 hours. Check your setting to make sure that it is set for a reasonable amount of time for you. We have the user manual at the link provided: DCC-1200 Manual. If you run into more issues with the auto off there might be a problem with the board in your machine. If that is the case you will have to call Cuisinart directly to get a repair auth for the machine.
Nov 01, 2010 | Cuisinart DCC-1200 Coffee Maker
My 12 cup cuisinart coffee pot keeps shutting off
I tried a solution someone posted on this site back in Dec and it worked, give it a try: "I called the company about the "shutting off after a brewing cycle" problem and they had me turn the dial to "auto off" and set the time to two hours. You do this by holding down the "hour" button until it blinks, and then press it again until you get the desired hours that the warming plate will be on. Hope this helps."
Mar 20, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker wont stay on after making a pot of coffee help
May 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Help, My comericial coffee machine is making 2 pots
Hello. I do not see a VPR manual with automatic functions, so your unit is not a VPR. Either way, it sounds like you have a scale build up on your level probe, causing the machine to over brew, until it can "see" the water again. This would require taking the top off, locating the probe, unplug please, remove by pulling out, annd cleaning the part that sits in the water. The other thing is you accidentally changed the time setting, here is a link to the manual,
http://www.bunn.com/pdfs/commercial/manuals/10179.0000.pdf
use the instructions to reset the whole time cycle on page 6, setting batch size. Then lock the timer to prevent future mishaps.If this is not your manual, but you have a Bunn unit, go to www.bunnomatic.com, and you can find the manuals to the left side of the screen.
Hope that helps, and thank you.
Apr 05, 2009 | Bunn VPR Coffee Maker
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart CBC-00FR 12-Cup Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
