Question about Federal Industries CGD5048 Commercial Refrigerator
How do you remove the plastic light covers above unit to replace lite bulb
How to remove light bulb cover Viking #1+
look on the left side of the machine and see if you see a little round plastic circle, very very carefully use a screw driver to pry it out , there should be a screw to unscrew and the side should come off so you can replace the bulb. if you will send me a comment with the complete name and model number, I'll see if I can find you a manual.
Jun 12, 2015 | Husqvarna Viking 1
How do I change light bulb
Lamp replacement requires removal of the outer cover to gain access. There can be dangerous voltage exposed inside even with power disconnected so extra caution is advised.
Sep 23, 2014 | Microwave Ovens
How do I get to the license plate bulb for a 2004 nissan sentra
There are 2 bulbs above the license plate, each under a plastic cover. The covers are held in with 2 screws each. Just unscrew and remove the plastic covers and you should be able to access the bulbs.
Mar 21, 2014 | 2004 Nissan Sentra
Change rear tail lite bulb for turn signal assembly removal of lens unit
plastic keepers in side of trunk hold carpet panel on back of lights remove and replace bulbs
Feb 07, 2011 | 2001 Dodge Intrepid
Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01?
Hi, just follow the instruction below...
1. Essentially, open the oven door and remove the plastic vent strip between oven and microwave (4 screws). There will be 2 screws under that which secure the microwave unit to the frame. Remove those...
2. Open the microwave door and remove the plastic vent shield at the top (3 screws). At that point, the microwave unit will slide out from the frame as describe above. The light is to the rear of the large silver pad (I removed mine to facilitate reaching the light). If you look at the parts diagrams online, it will be obvious what to look for. I have the light out and sure enough, OSRAM 64405S....
Took me maybe 5 minutes to remove...
Take care
Apr 23, 2010 | Kitchen Ranges
I am trying to replace the brake light bulb on 97
Open the trunk and remove the fabric insert located by the tail light. There should be 2 plastic nuts toward the center-most part, one above the other about 6 inches apart (One above the other). Then on the quarter panel side (where the light comes to a point on the outside) there should be just one. Making a total of three nuts to remove it. On the plug there should be a small plastic red clip. Slide it aside and squeeze the tab to remove the plug. After you pull the light out you will see two silver dollar sized circles that hold the light bulb in. Twist this to remove the light bulb. There's also a third smaller one for the smaller bulb.
Feb 24, 2010 | 1997 Plymouth Breeze
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
How do I change the license plate lights on a 1997 Lexus ES 300?
Open the deck lid (trunk) to better access the lights. There will be 2 of them. Recommend replacing both at the same time even if only one has failed. Generally sold in pairs anyway.
Directly above the license plate will be mounted 2 clear light covers. On the right side of each light cover you can see a small plastic rivet. Push in the center 1/4 inch with a small screwdriver then you will be able to pry out and remove the rivet without damaging it. This will save you from buying replacement plastic rivets for re-installation. Remove the light cover with the bulb harness attached.
The bulb harness requires a short turn counter clockwise to remove it from the light cover and the new bulbs snap into the harness. No twisting or screwing. Replace the bulb harness the same way and fasten the light cover back into place using the plastic rivet.
Saves time because both bulbs and light covers are exactly the same style, there is no left or right. Cheers!
Apr 29, 2009 | 1997 Lexus ES 300
License plate light
If you place the flate blade of a screwdriver to the right side of the light(s) housing. And push gently to the left the catch will release and the unit will drop out of the trunk lid. Twist the bulb 1/4 turn and remove. Just reverse the process to complete.
Open the trunk to eye level to see to make it easier to see. Applies to all 02-05 Devilles
Jan 03, 2009 | 2000 Cadillac DeVille
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Federal Industries CGD5048 Commercial Refrigerator Logo
Top Federal Industries Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Federal Industries Refrigerator Expert? Answer questions, earn points and help others
