I have a wurlitzer organ 4500 TCR .The board that has the diodes, connecting to the volume pedal; diodes are burned out. Where can I get this part?
4 Suggested Answers
  • 236 Answers
SOURCE: Hi, I found a Wurlitzer organ
You may have trouble finding the parts for that. But if you know a place where to get the parts for such brand and model then you just have to buy replacement for the rubber contacts of all the keys, it seems though sequencial keys maybe it got dirtied by some liquid and the owner did not try to clean and dry. maybe you can have it checked or try to keep a closer look in the keys, the area that keys doesnt work if any sign of liquid spill before. no use getting it if you find some sign of it.
Posted on Jun 19, 2008
  • 11 Answers
SOURCE: need # of amps of fuse for Wurlitzer 4100 Series organ
That means it is 1/8th Amp fuse. So the info you have is the fuse you need.
The other fuse (mains) is a 5 Amp
Posted on Oct 29, 2009
jakegolenor
SOURCE: Wurlitzer organ --need manual
I can make a copy of my owner's manual and send it to you. It's for a Wurlitzer Model 4430, also from the 1940s, 50s and 60s like the one you have. Would that maybe help? All I'd ask for is a couple of bucks for printing and shipping costs. If you want it, just reply to this post with an address or some way to contact you in order for me to obtain an address; I may be able to be talked into making a digital copy and emailing it to you if that's even legal. I'm not sure. You can look into that for me and let me know what you want/need :-)
Sincerely,
The Organ Donor
Posted on Nov 27, 2012
Wurlitzer C200 organ, volume pedal does not work, the Great keyboard is at full volume. Can't find anything online. Can you help me find information on repairing/replacing the volume pedal?
full volume ??? hum that's funny , as if pedal has broken one would suspect that it would go to lowest volume and stay there , 1st id ck to make sure the "bright" switch is not on or stuck on then id dive into taking the cover off the pedal assembly , for a look around to see if somethings obviously not right in there (hanging springs, swinging levers, etc)
Oct 13, 2016 | The Music
I need an owners manuel for a Wurlitzer 4300?
Try this: http://www.amazon.com/Wurlitzer-Organ-owners-manual-model/dp/images/B002UJXFYM
Afterwards, if this is NOT what you want, open up a browser window, type in google.com and then, enter Wurlitzer 4300 Owner's Manual. Amazing, huh?
Nov 04, 2014 | Music
My Stairmaster 4000 PT pedals have no resistance. I have replace the brushes on the alternator. Any ideas ?
have diode on the alternator checked , check all wiring connections to be tight, is the battery ok (6 volts ) and last check the motor control board for damage and/or electrical burn
Jan 17, 2011 | Stairmaster 4400 PT Stair Stepper
Very littel sound in white and black keys. normal
We can only guess at what model/brand you have.
OFTEN such low volume things can be traced to a burned out light used in some expression pedals that use light dependent resistors to vary the volume.
Be aware that on some organs things like rhythm drums MAY go through a different set of speakers and amps than the other voices.
Apr 30, 2010 | Music
Seeking all wire out, power and impedance info for Wurlly 4100
Try this link and contact Morelock's organ parts for a service manual:http://mitatechs.org/node/612 Please rate this if it helps.
Oct 29, 2009 | Music
Low volume allen organ adc 4600
IF the expression pedal uses a lamp and light-dependent-resistor, check for burned out lamp at the pedal.
Sep 06, 2009 | Music
Need # of amps of fuse for Wurlitzer 4100 Series organ
Apr 23, 2009 | Audio Players & Recorders
I have a Wurlitzer Omni 3000 organ that was given to me. When I turn it on, everything lights up but not getting any sound except in piano mode. With volume turned to maximum, you can very faintly hear the...
Hello!
I had several friends over the years who've had Wurlizer organs and they always "swear" by them. Guess they would be somewhat like Maytag products.
Anyway, I called one of them and she said she finally was able to get a partial solution from a friend of hers.
However crazy this sounds, she assures me that this procedure helped:
Look on the middle of the back of the organ, equidistant from corner to corner. There should be a knob of sorts which is kind of gold or bronze color. If the numbers haven't worn off, they should be around this knob. She said it works like this: turn the knob three times to the right, then four times to the left, and then push up. This supposedly resets the mechanism inside the organ that was loosened when your bench contacted the big pedal.
It's certainly worth a try, isn't it?
Apr 06, 2008 | Audio Players & Recorders
Sincerely,
The Organ Donor
Jan 11, 2008 | Audio Players & Recorders
57 people viewed this question
 Grubhead
Grubhead
