Question about Sony VAIO V2M (VGCV2M) PC Desktop
I have had this for about 2 years but i havnt used it for about six months when i tried to boot it it just will not boot to the operating system see the second picture for the error message the error message reads 'reboot and select proper boot device or insert boot media in selected boot devices and press a key' what do i do?vgc v2m
  • JDTec
    JDTec May 11, 2010
    It probably is not seeing the hard drive. Go into Cmos and check for the hard drive there.
  • Anonymous Mar 20, 2014
    turn on computer and in seconds a black screen pops up and and same message as above and it ask to insert boot media in selectedboot device and press a key. i no longer have any disc for this computer.
  • 489 Answers
Reboot the computer and press <F2> or <Del> in order to enter the BIOS Setup program. Normally on the first page, you will see information regarding the installed drives (sometimes it will be on the second page). Check to make sure that the system is detecting your hard disk. If it is not showing up, open up the computer case and check the cabling to the hard disk. There should be a 4-pin Molex power cable and a flat 80-pin ribbon cable connected to the hard drive. The ribbon cable should also connect to the first IDE socket on the motherboard (IDE0). Power up the unit again (leaving the case open temporarily). Listen to see if you can hear the hard drive spin up. If it does and the connectors are seated properly, the BIOS should autodetect the drive again and the system should boot normally. If this doesn't fix the problem, reply back here and we will try other steps.
Posted on Apr 23, 2009
    Problem Solver:
  • 5 Answers
Ok...
The FIRST thing you need to try, is disconnecting ALL un-necessary devices from the PC... Leaving only 4: Power cable, Monitor cable (unless the screen is built in... I didn't look up your model), Keyboard, and Mouse.
Try booting... We are attempting to determine if any other devices (iPod, Printer Etc.) are interfering with the standard boot process...
If that does not resolve the issue (it likely won't if nothing has been connected to the PC recently), you most likely have corruption on the hard drive's boot sectors... In English: the computer cannot find Windows' boot-up files...
There are SEVERAL ways to fix that hard drive problem without losing your data, but I must insist you let a professional handle that... 1 word: LIABILITY
One last thing... If the PC is SO old, that it has a floppy disk drive... Make certain there are no floppies in it... the PC will try and read that instead of your hard drive.
Dash lights and Radio Not working
All three circuits are on different fuses. Do you have power on the fuses for dash lights and the radio ? The radio should be using two different fuses, one for regular power and one for memory.
Jan 30, 2014 | Geo Prizm Cars & Trucks
How often do I change the filter on my Electrolux Jetmaxx
I can't answer that question, only you can....How often do you change the filter?
Now if you wish to know how often you should change the filter
every six months to a year depending on use.,,,once a week use- every year.....two or three time a week-every six months
Aug 09, 2013 | Electrolux Vacuums
When I turn my laptop on, the black screen lights up and all the lights on the keyboard turn on but then it all shuts down, and a few seconds later turns back on again. Nothing ever comes on the screen. It...
My first suggestion would be to boot from your Windows repair disk and run scandisk. You can run that from the command line. Just how you get to the command line depends on which operating system you have.
Basically, you want to boot from the CD/DVD and run a startup repair.
Additionally--is this machine still under warranty? If so, call HP (after all, you paid for at least one year service).
Jul 12, 2010 | HP Pavilion dv6000 Motherboard
Charger does not charge batteries
Check your charger with a voltmeter to see if it's putting out current. If you don't have a meter, try charging other batteries and see if it brings them up. If the charger is operating, your batteries may be too old/worn to take or hold a charge. Rechargeable batteries can last from as little as six months to over two years, depending on camera use and frequency of charging.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
Why has my Compaq required three system restores in six months?
Hey I guess, that maybe, maybe its the battery that is still hooked up is the one messing. It could be that when battery dies its electrical becomes short circuited looks like the battery will function as shorting wire thats why even you plug the cord it will eventually be shorted. And now, no power to battery then power supply gets shorted then no power to boot your system.
I suggest so should replace the battery with a new one.
Apr 07, 2009 | HP Compaq Presario 700, 700A, 700AP,...
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Trying to download Windows 2000 Registry Repair Utillity?
why are you using Windows XP boot disk instead of Windows 2000???
Nov 08, 2008 | Microsoft Windows 2000 Professional for PC
Forgot password to toshiba with vista operating system
Is it the windows password? Or did he set the bios password for booting up? If it is just the logon for windows, then the F2 setup won't be able to touch it. You can go here to fix the windows password:
http://support.microsoft.com/kb/321305
Feb 01, 2008 | Computers & Internet
Sony VAIO V2M (VGCV2M) PC Desktop Logo
296 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
