Paper is jam on the top feeder of Dell 1110
Can't get paper jam out of top feeder on the Dell 1110
  • 4,338 Answers
There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
Click on the user guide link .
http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
Printer paper jams can be caused from:
Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 23, 2009
Printer won't take paper
Regarding the paper not engaging with the Dell 1110 Mono Laser Printer, I previously read somewhere that taking iso-propanol (everyday rubbing alcohol, $1.00 for 24 ounces) and cleaning the centrally-located black roller (located just above the leading-edge of the paper) with a cotton-ball and the alcohol could solve the problem and it did -- My Printer Is WORKING. I was shocked! Actually, I couldn't find our bottle of alcohol, so I substituted with a chemically similar product. I used hand-sanitizer which is about 70% v/v ethyl alcohol -- a similar enough solvent. My Dell 1110 is working like it's brand new. Also, I wasn't able to rub the alcohol on the back side of the roller -- just a logistics problem that I couldn't solve without removing the entire roller. If anyone knows how to remove the rubber roller in 5 or less easy steps, I would love to know.
Mar 07, 2012 | Dell 1110 Laser Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Paper feed keeps jamming
There could be something blocking the paper input, turn it upside down and give it a shake, or if possible take the top off and have a look around for any obstructions
May 20, 2010 | Dell 946 All-In-One InkJet Printer
Dell Laserjet 1110 that won't print. Red light is on steady
When power on if your printer is red light>insert paper in tray.If red light is not go green.then you can get a decision paper sensor missing or paper jam or any sensor displace,check it .If you are not fix this problem,please open cartridge and insert again also the same problem.may be is fault fussier unite.please call a service technician who is expert this printer.
Dec 14, 2009 | Dell 1110 Laser Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
How can I un jam a paper jan in Dell 1720 laser printer?
Open the front cover and remove the toner cartridge to see if you can access the paper, if not open the top and inner cover to locate the paper and gently pull it out.
Jan 18, 2009 | Dell 1110 Laser Printer
Yellow light on and won't print on Dell model 1110 Lazer Printer
Dell printers are the worst I have worked with, this problem may be a 'paper jam' when there is no paper jam at all (or one REALLY stuck on the fuser). Check on the back of the printer for a piece of paper jammed on a sensor.
Dec 14, 2008 | Dell 1110 Laser Printer
False paper jam
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
1,184 people viewed this question
k24674
jasbo
jasbo
