Question about Toshiba SD7200 DVD Player
He@d 7200 cable usb pvr forgot the code to unlock or reinstall after i changed it, is it anyway to reset the code???
I forgot the code to unlock my phone
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 14, 2012 | Samsung Cell Phones
A friend of mine gave me a samsung highlight but did not tell me that there was a password lock and she forgot it. so now i can't unlock the phone. is there anyway i could unlock the password without...
There are few different unlock passwords for T749.
If you getting "Phone Lock" password prompt you need to reset Phone Lock. This can be done by flashing your phone with any firmware. You will need MultiLoader software and firmware files and a USB cable.
If you are getting "NetworkLock" or "Phone Freeze" you need to unfreeze and unlock code. This can be done by via USB cable but there is no free solution to make it. You can get software and instructions to read unlock/unfreeeze code at related links
Read more: http://wiki.answers.com/Q/How_do_you_unlock_password_for_samsung_SGH-T749#ixzz1WSX8HTBn
Aug 29, 2011 | Samsung Highlight Cell Phone
I forgot my security code on my lg imprint is there anyway for me to reset it?
Hi..
You can get the unlock code by contacting your current service provider customer care department. If your phone is locked you can use any of your friends phone to make this call.
The service provider will then provide you the unlocking codes. Everything is done for free of cost and you are not going to be charged for this process.
Another alternative is, you can take the phone to any authorize phone service center to help unlock the phone, because to unlock your phone, you will need some kind of software, USB cable etc to unlock the phone, so you can also go a nearby phone service center to unlock the phone, but calling your network service provider is the best because they have the records of your phone and can easily help to unlock it. This are the two reliable means you can unlock your phone..
Apr 06, 2011 | LG Cell Phones
I forgot my phone lock code sony ericsson p990i
Just go unlock your phone at www.unlock-zone.com
Rgards
Dec 20, 2010 | Sony Ericsson P990i Cellular Phone
I forget my security code for 2700classic, how can i unlock that
Hi
The default lock code is 12345.
If you changed it and forgot the security code please contacts your device dealer. They will reinstall the software fully and they will bring your mobile to default security code so that you can open your phone.
NOTE: While reinstalling the software all your contacts will be deleted.
While reinstall the software, device dealer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will start the process.
Reinstalling of software is FREE
Thank You
Aug 09, 2010 | Nokia Classic 2700 Cell Phone
I forgot the code to unlock LG enV. Is there
you could probably reset the phone to factory default
Aug 14, 2009 | LG enV VX9900 Cellular Phone
Need CODE to get second pin up on starview 2(THE BOX PVR)
You enter 1570.
Fixya!
Chris (ziraffa)
ps To put keys in manually do as follows.
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Jan 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
Cell phone password
If you take it to your SP they should be able to reflash the phone and bring it back to factory settings for you.
Mar 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Toshiba SD7200 DVD Player Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
