Question about Senco FP620 Framepro 602 2" - 3 - 1/2" Full Round Head Nailer
The nail gun shoots out 2-3 nails at one time, I clear the jamb & start over and the same thing happens over and over. What could be my problem?
  • 1388 Answers
SOURCE: Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Posted on Mar 16, 2009
  • 65 Answers
SOURCE: after each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
Posted on Mar 25, 2009
bargainbin2
  • 123 Answers
SOURCE: air bypassing when the trigger is pulled
You will need to get a repair kit for that model and brand nailer. It has a leek in the diaphragm or a bad O-ring.
Posted on Aug 29, 2009
  • 497 Answers
SOURCE: Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Posted on Nov 06, 2009
  • 142 Answers
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Posted on Dec 31, 2009
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
Paslode IM250 16 straight finish nailer, Fully charged battery, Green Light on, depress tip to start, fan does not start and unable to drive nails.
have you checked for a nail jamb, I've had this happen before on mine, It will jamb with the Piston part way out, have to release nails, and unsnap end and dig out nail with small screwdriver
Apr 20, 2011 | Garden
250B finish nailer has begun to shoot 2 nails at a time
try to regrind the driver blade, there should be a small nick on the driver blade where the nails are fed in, if the driver is to fat it will catch 2 nails,and cause nail jambs.
May 03, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
It is shooting 2 brad nails at a time - is there some type of adjustment?
the first thing that i look at when a gun is double shooting is the nails. if i have the right nails then i check the driver( part of the gun that hits the nail) if the driver is fine( not bent or broken or worn) then your nose( chamber that holds the nail right before being shot out) is worn or broken. either way to answer your question , no , double shooting is not only dangerous but a complete waste of time, ps rate , tks
Feb 15, 2010 | Air Tools & Compressors
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Campbell Hausfeld NS2190MVRB 21 Degree Round Head Framing Nailer is jammed. How do I clear it?
Remove any nails in the magazine, and you can carefully take a pin pinch of a size that fits into the nose (where the nails come out). Try to carefully tap the driver back into the gun.This will sometimes clear the jambed nail. If the driver is severely jambed you will have to dismantle the entire unit to separate the driver from the nose of the nailer.
Mar 24, 2009 | Campbell Hausfeld Tools & Hardware -...
Senco FP620 Framepro 602 2" - 3 - 1/2" Full Round Head Nailer Logo
44 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
