Logix tv 2601HT
Wall mount the tv. The guide says to remove the 2 posi screws holding base to base bracket but we cannot find the posi screws?
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
SOURCE: what is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
SOURCE: Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
Posted on Nov 07, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Remove base from TV
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
May 27, 2008 | Televison & Video
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
