Question about Polycom Telepresence m100 - License - 1 User - 5150-82725-001
Polycom Telepresence m100 - License - Polycom Telepresence m100 - License - 1 User - 5150-82725-001
How to reset the password of polycom hdx 7000
You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
Feb 27, 2014 | Polycom VSX 7000 Video Conference
Message NO ID message followed by beep beep...
ACTUALLY MAY POLYCOM SOUND STSTION ARE NOT DAMMAGE WHEN I BUY IT.WHEN THE TYPOON IS COMING SINCE ONDOY.MY POLYCOM SOUND STSTION ARE WET COZ OF TYPOON. JUST TELL ME WHERE IS THE SERVICE CENTER OF POLYCOM
Jan 07, 2011 | Polycom SoundStation
I have polycom 7000 with release version of 9.0.1 and second party having Polycom unit of 700 with release version now i am facing the poor video quality while connecting. Bandwidth at another end where...
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
Oct 14, 2010 | Polycom VSX 7000 Video Conference
Operation manual available? Quick guide available for IP 560 POLY
Hello Nicola,
You can find the user guides, setup and maintenance documents from polycom.com. Here is the link:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip560.html
Jul 29, 2009 | Polycom SoundPoint® IP 560 IP Phone
Polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
Jan 19, 2009 | Polycom VSX 7000 Video Conference
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
Connecting a polycom
No, i don't think si. The polycom needs an ethernet connection to a router. You might get this working by putting the 3g card into a PC and enabling connection sharing, however even if you got it work itsd a bad solution in terms of:
- Cost
- Reliability
- Security.
ADSL would be better.
Jun 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Polycom Telepresence m100 - License - 1 User - 5150-82725-001 Logo
120 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
