Question about Vga (CAT5-9000I) (EXTCAT59000I)
Axtrom xt vnx
Iu
2 Suggested Answers
SOURCE: viga driver
i want defination for vga drive
Posted on Oct 30, 2008
Konica 7920
Sir/ Mam,
The image unit could be bad. take alcohol and clean all metal contacts on the outside. Then reseat. GET a second one.
May 21, 2014 | Konica Minolta Imaging Unit 950-472...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
I dont have driver axtrom vga xt vnx95gt1gb
Assume its not plug in play at all. You might need to google for the driver and most likely buy it if its not on the manufactures website. If you used the SW disk to load the drivers first, uninstall those under Computer Devices. reboot the replug in monitor it should recognize as a universal plug and play monitor.
Jul 10, 2011 | Computers & Internet
How many mg are there in 1 i.u?
1 IU = 0.025 mcg
1 mcg = 0.001 mg
so look at it like this
1 IU per 0.025 mcg x 1 mcg per 0.001 mg = 1 IU per .000025 mg
so
there are .000025 mg in 1 IU
Jun 18, 2011 | Office Equipment & Supplies
Conversion of mu into iu
Hi, ibmpl,
I think I know what you are referring to! Sorry for the delay in responding to your question. Apparently, by mu you mean millimicron. Perhaps because of a limitiation in the formula editor for posting your message, you were not able to write the Greek symbol for micron.dubblea_8.jpg The "m" in front of the above symbol represents one-millionth of a micron, that is, 10^-6 micron.
The symbol IU is much easier to write in this forum, and means "International Unit." Unfortunately, the IU is not really a standardized international unit that can apply to any substance equally. It is not a part of the SI system (metric system of units), that is based on units of ten from the exceeding small to the exceedingly large, and which is firmly standardized across all chemical substances.
For example, 1 IU means something different depending on the substance. Here is a revealing list of well known substances and their different definitions for 1 IU:
  • 1 IU for Insulin = 45.5 micrograms pure crystalline insulin.
  • 1 IU for Vitamin A = 0.3 microgram of retinol or 0.6 microgram beta-carotene.
  • 1 IU for Vitamin C = 50 micrograms of L-ascorbic acid.
  • 1 IU for Vitamin D = 0.025 microgram cholecalciferol.
  • 1 IU for Vitamin E = 0.667 microgram d-alpha-tocopherol.
The reason for this range of values for the IU is its being based on a measured biological effect for each of these substances. That is, 1 IU has a different magnitude of physiological effect depending on the substance (often a drug, hormone, vitamin, or medicine).
Now, what I am going to say might be a disappointment to you: You cannot relate the millimicron to the IU no matter what substance you are describing. The reason is they are in different categories of measure. The millimicron is a metric system of LENGTH. The IU is based on measures of MASS. To convert one to the other they need to be in the same category of measure, length to length, or mass to mass. One COULD convert quantity of length to a quantity of mass, but only if you first convert either length to mass, or mass to length; but that would require the very inconvenient use of additional data, such as surface area and density of the substance of interest - a consequence too impractical for common use.
Jun 19, 2010 | Scientific Explorer My First Chemistry Kit
Bizhub C351 Magenta Image Unit Problem
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Jan 14, 2009 | Konica Minolta bizhub C351 All-In-One...
Viga driver
Apr 30, 2008 | Vga Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Vga Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
John Hong
John Hong
Are you a Vga Computer and Internet Expert? Answer questions, earn points and help others
