Question about Oreck Refrigerator Air Purifier Air Purifier
How do I change my oreck refrig filter - Oreck Refrigerator Air Purifier Air Purifier
I changed filter on oreck airstream purifier 2 days ago but light remains solid red.
you have to check OM. Usually you'd have tu push something 10 times to reset
Jan 22, 2018 | Oreck Air Purifiers
Can't find ORECK filter #AT2PK, been waiting for months for the ORECK store to get them. WHY!!!!!!!!!!!
They discontinued it. Just go to any aquarium and buy a carbon filter pad and cut it to size. They sell big sizes for under $10 and just stick it in your Oreck Air 5 air purifier. Works just as well and cheaper!!
Aug 27, 2013 | Oreck Air Purifiers
Why is my Oreck XL is my air purifier arcing?
If it was just clean recently, it's probably picking up dust particles and that's what you hear or see arching, like a bug zapper.And conversely, if it has been cleaned recently, dust particles on the filter are breaking off and getting zapped. In which case, you need to clean the filter.
Thanks for choosing FixYa.
Aug 25, 2011 | Oreck XL Professional Air Purifier
I need instruction on how to clean my Oreck XL.
Unplug the unit before cleaning. Wipe off the cabinet with a soft cloth and a mild non-abrasive cleanser.
To clean the electronic collector, loosen the front grill retainer screw then press in the lock and remove the grill. Pull out the collector by the tabs on the sides using both hands. Snap off the charcoal filter from the back of the collector. Then slide off the pre-filter. Spray the pre-filter and the collector with the Oreck Assail-a-Cell cleanser and then let stand for a few minutes before rinsing with water. Otherwise, soak the pre-filter and the collector in warm water (bathtub or sink) with mild dish detergent. Soak for 2-3 hours. Rinse well.
Then allow the parts to dry for completely before reassembling the air purifier. Air dry only.
Pictures to go with the Oreck XL Professional Air Purifier cleaning directions are in the manual. It is available here: http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf . See page 5.
I hope this helps.
Jul 06, 2011 | Oreck XL Professional Air Purifier
I have 2 and they smell bad. You have a bad reputation and I am going to return them to Canadian Tire if the odor problem is not resolved in the next 48 hours.
Stan, unfortunately what you're saying is not to Oreck, the manufacturer. This site is designed to help you determine what the problem is and hopefully, how to solve or repair the problem. But, not be threatened by what you want to do with your Oreck Air Purifier. Save that for Oreck.
With that said, I would have to ask you, when was the last time you cleaned or changed the filters on the air purifiers? I suspect that may be problem.
Mar 21, 2011 | Oreck (AIRCOM1BOI) Air Purifier
Can not find filters for this model. Do you know where I can find some?
I also have an Oreck Console Air Purifier a260. Like Moojenblue wrote on Oct 3, 2010, I cannot find replacement filters either. Thank you to anyone that may be of help. Mary Jo
Oct 03, 2010 | Oreck Console Air Purifier
Repair info for oreck md# a260 unit ran fine and worked well until I heard popping noise from front of unit probably bad connection of high voltage to filter cartrage fan stopped working if i turn unit on...
It depends on what you paid for it.I checked out Oreck and they had no free downloads available for anything.Here is their customer service though to find out about parts,diagrams,etc.Some places will not sell parts to consumers,some will.Here is the link.
http://www.oreck.com/SiteMap
Jul 27, 2010 | Oreck (AIRCOM1WOI) Air Purifier
Removing charcoal odor filter to clean
Hi, this is the manual for the Air8 series:
If that's not the right model, check the Oreck site:
http://www.oreck.com/Owners-Guides#
Jul 12, 2010 | Oreck XL Professional Air Purifier
Air Purifiers Logo
52 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
