Question about Savin "411113, Photoconductor Unit, Type 1013, Fax 3725"
Instructions how to install a photo conductor unit 1013 for a savin 3730 fax machine
2 Suggested Answers
  • 13 Answers
SOURCE: have a savin 8035e need to activate fax and scanning
This is the same as the Ricoh MP3500. You can find all the manuals here..
MP3500 manuals
Posted on Sep 17, 2009
What does 500 mean
Main Motor error(stuck). Replace Photo Conductor Unit.
Jul 15, 2015 | Ricoh Aficio MP 201SPF Fax Machine
What does time to change pcu mean?
Hi, PCU stands for photo conductor unit, most of us call it a drum unit. You should be able to order from any office supply. It is easy to install and will come with directions.
Oct 08, 2014 | Ricoh 3320L Laser Fax
Prints lines on copies. replaced photo conductor unit. didn't make a difference
if you already replace PCU still produce line on copy it could be fuser roller found at fusing unit. if black lines replace fuser unit or if available fuser roller much better but if white lines just clean laser unit. another problem may contribute might be deform frame of scanning section includes mirrors and alignment of lens unit this problem occur usually upon transport of the machine.
Dec 30, 2013 | Ricoh Aficio 1013 All-In-One Laser Printer
IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
Photo Conductor Unit Color
A Turn off the power, and then unplug the power cable.
B Open the right cover.
C Pull out the green levers on the left and right that are securing the inner
cover.Replacing
D Lift the inner cover until it stays up.
E Remove the photo conductor unit.
F Pinch the
green lever to unlock the unit.
G Pull out the photo conductor unit carefully.
H Pinch the green lever to unlock the unit.
I Pull out the photo conductor unit carefully until it stops.
J Pinch the green part to release the unit
.K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
L Take out the new photo conductor unit.
M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
Fax shows ''time to change PCU'' how can this be fixed?
you need to replace the Photo Conductor unit (drum unit).
Nov 17, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Replacing the photo conductor
You didn't mention make or model so I will guess. Most of the Savin/Ricoh brand small machines that have a small pcu require you to pull out a mylar strip in order to drop developer down where it needs to be. So my guess is that it needs to be pulled all the way out and on the end you will see a little bit of toner. Now alot, but a little on the end. Also the box that it came in should have some directions for installation. Good luck. Please rate this. Thanks.
Jul 01, 2009 | Office Equipment & Supplies
SC322 on Savin 4035
Laser synchronization error. It could be just toner on the LD unit. Try cleaning and doing the Pitch adjustment. If that doesn't work , then either the unit itself is bad, or the Sync. Detector board.
***This will obviously require a tech.
May 04, 2009 | Office Equipment & Supplies
PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Jan 22, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
Savin "411113, Photoconductor Unit, Type 1013, Fax 3725" Logo
51 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
