Question about Acer Aspire 3680 Laptop
My Aspire 3680 laptop screen cannot appear properly
My screen monitor doesn't appear properly,when I switch on,it appear grey,some image appear but didn't work like jammed something about that.can you help me?
  • 230 Answers
Try removing the plastic above the keyboard and wobbling the cable going to the monitor. Is the backlight appearing to work at all?
Posted on May 06, 2009
I have an acer aspire 3680 with a busted screen and i have been looking over other reviews but i have a computer screen which i am trying to hook up to the laptop to get some info i need off of it! but...
To get the image on the external monitor, power up the monitor first then boot up the laptop. The image will divert to the external monitor automatically.
Jan 07, 2010 | Acer Aspire 3680 Laptop
Hi, just turned on my acer aspire, and whilst power is going through it, the screen won't come on. is this a common problem?
Does the laptop appear to boot up but cannot see an image on the screen?
If this is the case the LCD screen maybe faulty.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 07, 2009 | Acer Aspire 3680 Laptop
I've tried to on my laptop (acer aspire 3680), but the lcd screen is blank even it already turned on..
check the display on exter monitor through the vga port, if its there then its the fault of the screen, if its not then its the fault of the motherboard of laptop take it to the service centre
Sep 26, 2009 | Acer Aspire 3680 Laptop
Solution for "my laptoop seems to want to boot but when is is done booting the screen turns black and remains that"
If the laptop appears to boot up and you can't see an image on the screen, you need to determine if the screen is faulty or the video card.
Connect an external monitor to the laptop's external video port, power up the monitor first and then boot up the laprop. If you get a normal video image on the monitor then the video card is OK and the fault is with the LCD screen.
If you don't get an image or POST information, then the LCD screen could be faulty or the laptop didn't boot up.
Please get back to me with the results of your tests and any error messages etc. so I can advise further.
Jun 18, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer Aspire 5050-3242 Notebook
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
or
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
DISPLAY PROPERTIES>Settings
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Click IDENTIFY.
ONE SCREEN-
Should display a number 1 on the screen it has attached.
TWO SCREEN
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680
Display Toggle - <Fn> + <F5> will toggle from external monitor
Screen Blank - <Fn> + <F6> will turn the LCD off
hope that helps.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Replace Monitor
You may google under option more and then under products search by typing Screen Aspire 3680-2682 or you may go to www.ebay.com and type the same thing and there you may find used ones.
Jan 16, 2008 | Computers & Internet
Acer aspire 3680 MONITOR backlighting problem.
its u r laptop lcd problem.so please replace u r lcd
Jan 11, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
