Question about Kenmore Elite HE4 Electric Dryer
3 fast beeps then won't start
The dryer has worked great for 2 years, then this AM, not so much. Press start,just get the 3 fast beeps I have unplugged and replugged, checked the circuit breakers, thoroughly cleaned the lint filter, checked the door lock, now what?? I would take the control panel off and check that but I don't know how to get it off. I think I should just go back to hanging the laundry outside.
  • ctslich Apr 23, 2009
    The light burned out this morning when I open the door. It flashed the way a light bulb often does when you turn on a light switch. It wasn't the type of thing where the door was open and not making contact so the light burned out. Do you still think it's the door switch? I can push on the switch and feel pressure and the door seems to be closing firmly.
    The other thing that happened this morning is that a GFI outlet tripped that is on a kitchen circuit. I'm not sure how that would impact the dryer since it's on a 220 outlet, but that was oddly coincidental. I hit the reset button on that and it's working fine now. And as mentioned before the lights on the control panel are working.
    Is replacing the door switch a task for a trained service provider or something I can do?
  • 3,866 Answers
There is a limit circut with the timer that needs replacment. My aunt has the same problem the timer that stops the machine went out and she had a tech put in a timer switch or circuit and it works great . she only paid $29.99 for the guy to do all the work and parts. If you find this helpful you can hit accept. thanks
Posted on Apr 23, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    Something sure surged it thats for sure dont matter if its on a 220 or not you still can get back flow so if you think its the door switch that needs repair instead of the timer still its going to need someone professional to look at it, Thanks for using Fixya.com
  • 1,170 Answers
It seems that the door closure switch is a common failure point. The common theme is the dryer interior light burning out. The door switch fails, so the light stays on, and burns out. Then you try to do a load and the dryer will not start due to the switch not making contact. It could be an intermittent problem too. Replacing the door closure switch will solve the problem.
Another guy had this same problem, and apparently the problem was that the door latch was not operating to the extent that the sensors thought the door was open. He replaced the latch next week. He adjusted the old one in the mean time and it appeared to be working fine.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
F 70 code on the Kenmore elete smartheat HE4
hello Whgispers42,
Huuum At your service!
You said,
We frequently have to start the dryer several times during one load. The dryer will run fine for a while then all the sudden give 3 beeps and then the F 70 code. Sometimes when you go to start the dryer you can press power and the panel will light up for about 3 - 5 seconds and then shut off again, this will happen several times in a row. We have been unable to solve this issue ourselves and are becoming very frustrated since this washer/dryer set are less than a year old. Any help you could offer would be greatly appreciated. (If we are unable to fix this problem soon, it is likely that the dryer will make a sudden leap from the second floor window to the backyard)
Try this first!!
This is an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not help, you said the machine is not one year old.
All appliances have a 1 -year warranty and the service and parts are free for that first year!
I hope you succeed with my recommendations.
Please contact me with your progress1
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Jul 27, 2008 | Kenmore Elite HE4 Electric Dryer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
GE DPGT750GC Gas Dryer Problem
Using the
Troubleshooter
To locate Troubleshooting Tips for common dryer
problems:
Press the HELP button.
2 On the Touch Screen, select TROUBLE
SHOOTER
3 On the Touch Screen, select the problem
description from the list. You can use the arrows
at the right of the screen to scroll up and down
through the list of additional problems.
4 On the Touch Screen, select a possible cause
for the problem and follow the on-screen
instructions to find a solution.
Pressing the HELP button then selecting HOME
SCREEN HELP
allows you to find additional
information on features found on the Home
Screen. Touch any pad on the Touch Screen for
an explanation of that feature. To exit the feature,
press the BACK button.
DID YOU ATTACH THE SERIAL CABLE?
Attach the serial cable for washer and dryer
connection to the serial port on the back of
the dryer.
Attach the other end of the cable to the
washer before pushing the washer into its
final position.
Problem Possible Cause What To Do
Dryer won’t operate Control panel is asleep • This is normal. Press POWER, the
touch screen or any button to activate
the control panel.
Dryer is unplugged • Make sure cord is plugged securely into
a working outlet.
Controls are not set properly • Make sure the cycle was set correctly,
close the lid and press START.
Fuse is blown/circuit breaker • Check house circuit breakers/fuses.
is tripped Replace fuses or reset breaker.
NOTE: Electric dryers use two fuses
or breakers.
Electronics need to be reset • Unplug dryer, wait 2 minutes, plug
back in and press POWER.
START was not pressed after • Press START.
a cycle was set
Door was opened during • Close the door and reset cycle, to the
the dry cycle beginning if necessary. Press START.
Dryer is too cold • If the dryer has been exposed to
temperatures below freezing for an
extended period of time, allow it to
warm up before pressing POWER.
Otherwise, the display will not come on.
Hope some of this helps. here is a link to the manual:
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750GCPL
Nov 29, 2007 | GE DPGT750GC Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
