Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
I have a tecumseh 195cc 6hp engine on a go cart when i try to start it instead of pulling gas into the engine it pushes it out of carberhater
3 Suggested Answers
vincob
  • 718 Answers
SOURCE: My Tecumseh engine stopped running but was not out of gas. When I tried to start it would not and gas is coming out of the air filter. I took off the carb bowl and float seems to move ok
Your float might have a hole in it and is full of gas. You need to take it off and shake it to see if gas is in it, or float pin is faulty not closing correctly.
Posted on Oct 26, 2012
  • 50511 Answers
SOURCE: I have a 6hp Tecumseh engine that want take the gas when it runing!
possible part blocked main jet or low fuel supply from blocked filter in the tank
Posted on May 11, 2016
May 10, 2016 | Tecumseh Garden
Tecumseh 195cc
Those are engine numbers not buggy numbers, use tape measure inside the pulleys to get approximate size then experiment with different sizes
May 29, 2013 | Mtd Garden
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I've got a sears custom 600, engine is a 143-556112 6hp. what is the tecumseh #'s
If you go to the SEARS Parts web site, the SEARS Part Numbers are the same as the Tecumseh Part Numbers.
Nov 27, 2010 | Tecumseh Garden
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
Broken piston connecting rod
The rod is cheap. If you're an experienced handymand/mechanic, it's a medium difficult job. But if the rod damaged the engine when it cam loose, the engine will have to be replaced. Need to tear it down to investigate.
Charlie
Aug 25, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
