Question about Admiral Washing Machines
We just got a new Admiral Washer, model ATW4675YQ1 and the tub takes forever to fill. The water starts flowing fast and with lots of volume and shortly after doesn't have much volume at all. What can I do?
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
Yozzer6821
  • 116 Answers
SOURCE: Admiral Washer Model# AAV7000AWW
Your problem sounds like a defective water level switch, the rinse switch bypasses this switch therefore your get water whan you go to rinse.
lift the top cover, look at the front of the machine, insert a flat knife approx 4" in at each side of the seam between the front panel an the lid to release the clips, this will allow you to lift the lid, the water pressure switch is at the back (usually round with 3 wires and a small hose to the outer drum low down, ensure the small hose is connected, or with a mais tester check the output (orange/purple wire terminal 2), no mains voltage=no water, the input is grey (terminal 1) from the timer and should be live, the 3rd wire is the output telling the timer "the washer is full" (light blue terminal 3) and will be live when full.
Posted on Apr 13, 2008
ginko
  • 19396 Answers
SOURCE: washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Posted on Feb 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Posted on Feb 28, 2009
Samyfam
  • 379 Answers
SOURCE: my washing machine is taking a long time to fill.
Have you checked the inlet filters on the water hoses ?
If you unscrew the water hoses from the machine, and look inside the connections on the machine, you should see the filters - they are usually a plastic "cage" supporting a gauze or fine mesh. These can be pulled out (you may need tweezers or fine nosed pliers) and washed under a running tap.
If this doesnt cure it, check that the water supplies where the hoses connect to your house plumbing are actually fully on and flowing properly.
Otherwise, there is probably a fault with the solenoid valve(s) on the machine that controls the flow of hot water in to your machine.
Posted on Nov 08, 2009
Testimonial: "great suggestion! my life is so busy being a stay at home mom that i dont have time to wait forever for my washer. fixed it up great!"
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
Maytag performa dishwasher, model # PDBL390AWB.
Sounds like to me you have a water restriction somewhere. Double check and make sure that the main water valve coming into your home is fully open. Make sure the water shut off valve(s) going to the dishwasher both have adequate water flow and that means testing them before being connected to dish washer. If that checks out okay, possibly the plunger that opens and closes in the electric water solenoid is sticking and not opening up al the way since the unit has been in storage for all that time. Sometimes tapping on it when it is in operation can free up that sticking plunger and you may get full water flow restored again. If not, solenoid may have to be replaced. Hope this helps out.
Mar 09, 2014 | Dishwashers
Takes forever to fill tub
yes now days all the faucets are regulated to save water so they dont fill a large tub very fast. if you take off the diffuser (the screen wher the water comes out) depending on the brand you might find a plastic disc that restricts the flow. Take that out and see if that helps. Try just taking off the screen assembly and filling the tub first. It it does not fill faster with that off then you have another problem,and taking out the restrictor plate wont help.
Nov 26, 2012 | Coral Sea Spas Ariel Platinum DA333F8...
What is LF message
LF means a long fill was detected. This means that the washer sensor did not sense enough water coming into the unit in the first 8 minutes after starting the wash cycle.
There are several things that you can check. First, make sure that the incoming water pressure is good. You can try replacing the intake hoses and checking the filters on both sides (inside the washer and at the shut-off valves). (When you take the hoses off the shut-off valves, put a bucket under the outlets and check the flow rate.) Some intake hoses will seal themselves if they detect a leak. This will significantly reduce the water flow. If the filters are clogged, you get a similar restricted flow.
Next, check that the end of the drain hose is not positioned below the fill level of the washer. This will cause the water to be suctioned out of the tub as fast as it fills.
If the water is flowing well, the intake valves or the water pressure sensor (which detects the change in the weight of the tub) could be bad or have a wiring harness problem.
I hope this helps.
Aug 25, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
When my son's new Kenmore washer is filling up it starts off with the water rushing in like it should but after about a minute the flow falls back to almost nothing and it takes forever to fill up.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Feb 28, 2009 | Admiral AW22 Top Load Washer
Washer fills up only half way but water keeps trying to fill tub
Feb 20, 2009 | Admiral AW22 Top Load Washer
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
323 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
