Question about LG WM2101HW 4.0 cu.ft. Washer
LG WM2101HW Door is stuck closed. Will not release or come open with a little torque. Any suggestions are appreciated
4 Suggested Answers
SOURCE: faulty door catch on my LG washer?
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Posted on Jan 30, 2008
MNTECH
  • 1543 Answers
SOURCE: My LG Tromm detergent door is stuck closed and I
Here's what I would do:
Take the two screws off the back plastic parts which are attached to the top cover. Leave the ones in that go into the cover, just remove the bottom one on each side.
Now, standing in front of the machine, use the palms of your hands to sharply push back the top cover (pushing on the right and left edge of the top). It only moves about two inches. Now, lift the cover off.
Use a flashing to try to see into the semi opaque dispenser to determine where the hang up is.
Drill a small hole in the top of the dispenser chamber to allow you to poke an object like a screw driver in to manuver the offending part of the dispenser, allowing removal of the dispenser drawer. Use a peice of foil duct tape to seal the hole you previously drilled.
Posted on Jun 12, 2009
SOURCE: front door does not release
press the pause/ play button. This will unlock the door
Posted on Jul 11, 2009
My LG WM2101HW washer door will not lock. Sometimes if you shut the door just right, it will work. I ordered and replaces the actually door switch, but it still will not lock. What else can I do?
You say that you replaced the door switch, but you need to check that the spring of the latch hook inside the door is working properly, otherwise it does not hook properly and will cause these problems.
Jul 28, 2016 | LG WM2101HW Front Load Washer, White, 4.0...
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Door does not ope or close properly
might door handle was broken because of that its haperning,,
Feb 20, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
My LG WM2101HW front loader will not spin. It drains OK, but won't spin.
I would be leaning more in the direction of the door lock mechanism rather than the hall sensor as someone else posted. The hall sensor gives a very specific error code when it goes bad. Put the unit into a spin only cycle and verify that the door is locking. To do this power up the machine and only press spin speed and the start. It is also possible that it is a problem with any one of the three control boards that are on the unit but again, these normally present with very specific error codes. If the door is not locking, or even if it is but the switch isn't sending the signal back to the main control saying that it is locked then all it would do is drain and then spin 1/3 turns either way inside the tub until time runs out.
Nov 14, 2012 | LG WM2101HW 4.0 cu.ft. Washer
The locking mechanism in my door is stuck in the closed position. that little "c" hook isnt moving at all, and my door will not fully close. is there a release latch somewhere?
Open the car door and pull on the release latch that you use to open the car door from the inside to get out. At the same time use a screwdriver to push up the latch on the side of the door. Sometimes the seatbelt gets caught on the door when you close it causing the latch on the side to close prematurely.
Jan 27, 2011 | 2001 Chevrolet Blazer
WASHER WONT FILL DE SHOWS ON SCREEN
its the door error the door not closing all the way.shane
Dec 19, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Where is the serial number on the machine? We have a front loading LG washing machine.
When you open the door it should be on a 2" x 3" white sticker around the door opeing
Nov 09, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Re: Lg Lrtpc1831t
Shirlee, you might not have the refer leveled right. The doors should close by themselves when released. Have someone bring the front levelers down so it is pitched back a little. This should eliminate the freezer door staying open. This is caused by the rush of air from the lower compartment to the upper compartment during closing.
Nov 03, 2006 | LG LRTN19314 Titanium Top Freezer...
LG WM2101HW 4.0 cu.ft. Washer Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
