Question about Cycling
I dont know how to connect the brake cables to the brake level
How do i install brake cables?
    Scholar:
  • 34 Answers
Go here and look through the video's. There should be something for installing brake cables. Your install will depend on what type of brakes you have (side pull, v-brakes etc).
Posted on Apr 23, 2009
Excursion limited edition. Brake lights stay on.
Check that the pedal height isn't sagging due to low brake fluid level. Also check for adjustment of the brake light switch or the BPP (Brake Pedal Position) switch.
Brake Pedal Position (BPP) Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect brake pedal position (BPP) switch electrical connector.
  3. Remove self locking pin.
  4. Remove switch from brake master cylinder push rod.
  5. Remove push rod spacer.
  6. Remove push rod bushing.
To Install:
  1. Install push rod bushing.
  2. Install push rod spacer.
  3. Install switch to brake master cylinder push rod.
  4. Install self locking pin.
  5. Connect electrical connector.
  6. Connect battery negative cable.
Jan 25, 2011 | 2003 Ford Excursion
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
How do I replace the brake fluid level sensor on a 2004 pontiac grand prix
  1. Disconnect the negative battery cable.
  2. Detach the electrical connection from the fluid level sensor.
  3. Remove the fluid level sensor, using needle-nose pliers to compress the switch locking tabs at the inboard side of the master cylinder.
    Fig. Location of the fluid level sensor
To install:
  1. Insert the fluid level sensor unit until the locking tabs snap in place.
  2. Attach the sensor electrical connector.
  3. Connect the negative battery cable.
Oct 16, 2010 | 2004 Pontiac Grand Prix
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
How do I replace the ear brakes?
Bonneville, LeSabre, Park Avenue 2000-2005
Brake Caliper - Removal & Installation
CAUTION Dust and dirt accumulating on brake parts during normal use may contain asbestos fibers from production or aftermarket brake linings. Breathing excessive concentrations of asbestos fibers can cause serious bodily harm. Exercise care when servicing brake parts. Do not sand or grind brake lining unless equipment used is designed to contain the dust residue. Do not clean brake parts with compressed air or by dry brushing. Cleaning should be done by dampening the brake components with a fine mist of water, then wiping the brake components clean with a dampened cloth. Dispose of cloth and all residue containing asbestos fibers in an impermeable container with the appropriate label. Follow practices prescribed by the Occupational Safety and Health Administration (OSHA) and the Environmental Protection Agency (EPA) for the handling, processing, and disposing of dust or debris that may contain asbestos fibers.
Inspect the fluid level in the brake master cylinder reservoir. If the brake fluid level is midway between the maximum-full point and the minimum allowable level, no brake fluid needs to be removed from the reservoir before proceeding. If the brake fluid level is higher than midway between the maximum-full point and the minimum allowable level, remove brake fluid to the midway point before proceeding.
  1. Raise the vehicle and suitably support.
  2. Remove the tire and wheel assembly.
  3. Pull down on the front park brake cable.
  4. Remove the front park brake cable from the park brake cable connector.
    NOTE When using a large C-clamp to compress a caliper piston into a caliper bore of a caliper equipped with an integral park brake mechanism, do not exceed more than 1 mm (0.039 in.) of piston travel. Exceeding this amount of piston travel will cause damage to the internal adjusting mechanism and/or the integral park brake mechanism.
  5. Install a large C-clamp over the top of the brake caliper housing and against the back of the outboard brake pad. Compress the brake caliper piston into brake caliper bore to allow the piston enough clearance to slide the brake caliper off the brake rotor.
  6. Remove the C-clamp.
    NOTE Be sure to plug the opening in the brake caliper and brake hose to prevent fluid loss and/or contamination.
  7. Remove brake hose to caliper bolt attaching the brake hose to the brake caliper.
  8. Remove the brake hose from the brake caliper.
  9. Remove and discard the two copper brake hose gaskets. These gaskets may be stuck to the brake caliper and/or the brake hose end.
  10. Remove the park brake cable bracket from the brake caliper. Leave the park brake cable attached to the cable bracket.
  11. Disconnect the park brake cable from the park brake lever on the brake caliper.
  12. Remove the lower brake caliper pin bolt.
  13. Rotate the brake caliper up.
  14. Remove the brake caliper from the upper brake caliper pin bolt.
To install:
  1. If reusing the brake caliper retainers, clean the sleeves using denatured alcohol, or equivalent.
  2. Lubricate the brake caliper pin bolts with a thin coat of high temperature silicone lube.
  3. Install the brake caliper to the upper caliper pin bolt.
  4. Rotate the brake caliper down over the brake pads into the brake caliper bracket.
  5. Install the brake caliper pin bolts. Tighten the brake caliper pin bolts to 27 Nm (20 ft. lbs.).
  6. Remove the plugs in the brake hose end.
    NOTE Install NEW copper brake hose gaskets.
  7. Assemble the brake hose bolt and the NEW copper brake hose gaskets to the brake hose.
  8. Install the brake hose to caliper bolt to the brake caliper. Tighten the brake hose to caliper bolt to 44 Nm (33 ft. lbs.).
  9. Connect the park brake cable to the park brake lever on the brake caliper.
  10. Install the park brake cable bracket to the brake caliper. Tighten the park brake cable bracket bolt to 43 Nm (32 ft. lbs.).
  11. Install the front park brake cable to the park brake cable connector.
  12. Bleed the brake system.
  13. With the engine OFF, gradually apply the brake pedal to approximately 2 / 3 of its travel distance.
  14. Slowly release the brake pedal.
  15. Wait 15 seconds, then repeat until a firm brake pedal is obtained. This will properly seat the brake caliper pistons and brake pads.
  16. Install the tire and wheel assembly.
  17. Lower the vehicle.
NOTE The Bosch 2U ABS system cannot increase brake pressure above master cylinder pressure applied by during braking. There is no need to depressurize the system prior to service.
  1. Remove brake fluid from the master cylinder reservoir until the reservoir is approximately 1 / 3 full.
  2. Remove the front wheel. Mark the position of the wheel to the wheel studs, prior to removal, for installation reference.
  3. Install 2 lug nuts to retain the rotor once the caliper is removed.
  4. Using a large C-clamp, bottom the piston in the caliper bore by positioning the C-clamp on the outboard pad and on the round portion of the brake caliper where the piston is housed.
  5. Remove the banjo bolt that fastens the brake hose to the brake caliper. Discard the gaskets.
  6. Cap the brake line to avoid excessive fluid loss or fluid contamination.
  7. Remove the rubber dust boots from the caliper mounting bolt heads (if equipped).
  8. Remove the caliper mounting bolts.
  9. Remove the park brake cable from the caliper.
  10. Remove the caliper from the vehicle.
  11. Remove the brake pads.
To install:
  1. Install the brake pads. Lubricate the slides where the caliper mounts on the steering knuckle with silicone grease.
  2. Install the caliper over the rotor.
  3. Install the caliper mounting bolts. Torque the mounting bolts to 38 ft. lbs. (51 Nm).
  4. Install the park brake cable.
  5. Install the rubber dust boots over the caliper mounting bolt heads (if equipped).
    Fig. Measuring the caliper clearance
  6. Check the clearance between the brake caliper and caliper bracket stops. If the clearance is too tight, check the caliper leading and trailing edges for build up. File down as necessary.
  7. Connect the brake hose to the caliper. Install the brake hose banjo bolt, using new gaskets, and torque to 33 ft. lbs. (45 Nm).
  8. Remove the lug nuts used to secure the rotor.
  9. Install the wheel, aligning the reference marks made during removal, and torque the lug nuts to 100 ft. lbs. (140 Nm).
  10. Refill the master cylinder and bleed the brake system using the recommended procedure.
  11. Road test the vehicle and check for proper braking performance
Hope helps (remember rated this).
Jul 08, 2010 | 2003 Pontiac Bonneville
I Have a 2002 Dodge Ram 2500.Both the ABS and Brake Lights are on
did you check the brake fluid level? you dont just go replacing parts without knowing what is bad. The abs unit will have trouble codes, get those codes and tell us what they are.
Jun 04, 2010 | Dodge Ram 2500 Cars & Trucks
I need the long piece what goes between the back brake caliper and the brake pedal but dont know where to find 1 and dont know what the piece is called.any ideas would be great.thanks
this is usally called the "rear break cable" it comprises of a thin steel braided cable which is visible at the brake caliper end and is shethed in a fexible outer sleve.
it is possible to replace the rear brake cable without having to change the flexible outer.
Jan 01, 2010 | Pit Cycling
Console brake light stays on I checked fluid level and it is good. I Pulled parking brake and it is working fine but light does not turn off.
I dont know which brake light is the console light but fluid level needs to be FULL. You might even disconnect the fluid level sensor just to be sure its not lying. Does the brake pedal feel normal? if not, have it looked at. May be the parking brake switch is bad?
Nov 16, 2009 | 2001 Kia Rio
FRONT BRAKES
very simple system my man. the brake handle connected to the master cylinder connected to the brake line connected to the calipers via the plumbing in between. so check your fluid level first if its low then top off and bleed those babies. also check the pads because as the pads wear the piston in the caliper moves further out so more room in the system so lower fluid level or you got a leak. or the master cylinder is bad. start with the obvious and dig deeper good luck and let me know tell me more about the malfunction too
Mar 30, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Cycling Logo
675 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
