Question about Karbonn K9
How to copy contacts from phone memory to sim memory(bulk)
How do I copy contacts from phone to sim card on my Samsung 7272r
  1. Find "Import/Export contacts" Tap Contacts. Tap MORE. Tap Settings. ...
  2. 2a - Copy contacts from your SIM to the phone memory. Tap IMPORT. Tap SIM card. Tap Device.
  3. 2b - Copy contacts from the phone memory to your SIM. Tap EXPORT. Tap SIM card. Tap EXPORT.
Nov 28, 2016 | Samsung Cell Phones
How do I delete contacts from sim card
copy the contacts on the sim card to a sd card in the phone. If you don't have one, get one and put it in the phone. Set up the memory in the phone to both sim and memory card. Copy the contacts onto the memory card. Remove the memory card and then go about deleting the contact list in the phone. Put the memory card back in the phone and set the memory in the phone touse the memory card only...not the sim. You're done.
Feb 24, 2015 | Cell Phones
How to copy or take backup all contacts from phone memory to memory card in nokia c5 mobile. plzzz tell me the solution for this problem...
go to settings->sync and backup->create backup->select contacts and press done it will automatically backup to memory card..
Oct 05, 2011 | Nokia C5 Cell Phone
How can i move my contacts from memory card to phone memory in nokiaC3
Unfortunately, the nokia C3 does not support the copying of contacts to the memory card and vice-versa.
You can only copy contacts between the SIM and phone memories.
You can do this by highlighting the contact you want to copy and selecting the options then more button. This would ask you if you want to copy to the other memory.
Hope this helped you?
Jun 07, 2011 | Nokia C3 Cell Phone
I transferred all the phone numbers from my old sony ericsson cell phone to my sim card, but cannot figure out how to copy all the sim numbers onto my new sony ericsson vivas pro.
To transfer your contacts through the SIM card:
  1. Copy your contacts from your old phone to your SIM card. If you need help with this, please consult the old phone user guide.
  2. When the copying is done, move the SIM card to your new phone.
  3. Select Menu > Contacts.
  4. If the phone asks you to copy info from the SIM card, skip steps 5-10.
  5. Otherwise, tap Options > Settings > Contacts to display.
  6. Select SIM memory > OK, then tap Back.
  7. Tap Options > Mark/Unmark > Mark all.
  8. Tap Options > Copy > Phone memory.
  9. Tap Options > Settings > Contacts to display.
  10. Select Phone memory > OK, then tap Back.
Feb 28, 2011 | Sony Ericsson Vivaz Cell Phone
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
How do i copy from Phone to SIM. I bought a new phone. I wanted to use my old SIM but when I fitted in the new bobile the contact was expty . All my contacts are in Phone memory how can I copy from phone...
when you go to contacts you will have an option copy from phone to sim or move from phone to sim and vice versa
Make sure that the memory is selected as phone and sim to view contacts in it
Hope this works
Feb 02, 2010 | Nokia 5310 Cellular Phone
Copy contacts from sim to memory card on samsung
Go to contacts. Hit the contact you want to copy to sim. At the bottom right it says MORE. Touch that and the option to copy to sim is there.
Jan 09, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I want to copy contacts in Nokia N70 to another phone
hiiiiiiii first of all delete all the contact in sim memeory by performing following step.
goto contact>>then on option>>sim contacts>>sim directory and see all the sim contact and the one you wanna delete delete their.and if you want to keep all the contact then make a folder in memory card by
goto menu>>tools>>file manager>>memory card>>make a new folder contact. and copy your contact to memory card.then put your memory card in card reader and from memory card to computer
Oct 07, 2009 | Nokia N70 Smartphone
How do i transfer my contacts from phone to sim - Nokia 5140i
Search for the contact you want to copy and select Options > Copy. You can copy
memory, or vice versa. The SIM card memory can save names with one phone
number attached to them.
Oct 06, 2008 | Nokia 5140i Cellular Phone
Karbonn K9 Logo
51 people viewed this question
Top Karbonn Cell Phones Experts
akshay
Level 1 Expert
Tom Chichester
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
