Question about H2o TR220002 Steam Cleaner
My h2o steam mop won't hold water in water resevoir when i put it into the machine it leaks out
3 Suggested Answers
SOURCE: My h2o mop will not
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Posted on Oct 15, 2011
SOURCE: my brand new h2o mop
bought it a few years ago - I used it a few times and it was fair but did leae a lot of water on the floors. My wife had wanted it as it was supposed to be a miracle device, but she had some health issues and not able to do heavy housework. She is better now and decided to try this miracle device she had wanted so bad - so we took it out and no steam - so this would be it's 3rd use and it's was dead. I'm a bit of a tinkerer so decided to take the thing apart/clean the nozzles etc per the troubleshooting guide. Well, none of the obvious/accessable nozzles were clogged, and the filter seemed to pass air and water ok (probably does have to be changed due to time vs uses. Anyway, took the unit apart and ended up having to take the pump motor apart - there is a little nozzle/connecter on the back of the motor that passes the water into the heating chamber. cleaned that with a pin - put it back together, and tons of steam shooting half way across the room. So - she did the floors, they are wet but clean. Bottom line - does an ok job but leaves a lot of water behind, and it appears the internal nozzles can be a problem, and not something the average householder would want or be capable of fixing. (they do say you can try using WD-40 in the unit to clear nozzles - not sure how it would get through to the pump nozzle, but maybe this would work ??
Anyway - may end up buying some more filters as we will want to get a few more uses out of this thing for our $100 bucks, but will stay away from them in the future (go back to the wet swiffer - does about the same job but much less cost and hassle).
Posted on Oct 14, 2012
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
My H2O mop will not shoot out any steam.
This sounds like a water supply problem and maybe be plugged in a part of the system if you have enough water in the reservoir.
Sep 21, 2014 | Vacuums
How to get steam out Clogged h20 mop
Put vinegar in it and let it sit for several hours. Then turn it on to heat the vinegar. It should start to sputter and you may see some material ejected. This is good. Now dump out the vinegar and fill with water, make steam and let it push out any more material that caused the clog. You may have to do this several times in order to get the vinegar smell out.
Jun 28, 2014 | H2o TR220002 Steam Cleaner
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
My h2o mop will not allow any water flow the red light comes on after afrw minutes the green light comes on but there is no water or steam flowing out what can i do
Apr 13, 2011 | H2o TR220002 Steam Cleaner
The water tank is getting really hot,steams come out the sides of it but no steam is coming out the bottom.
I was having the same problem. No steam out the bottom. I took the whole thing apart and cleaned it...inside and the mop heads. I now get water to the heads but steam is still coming out the sides of the unit and leaking. I took it apart again and this time had my husband look at it. He found a tube with a spring in it...the spring had punctured the side of the tube and was leaking inside the machine! I am really upset by this as the machine never really worked right from the beginning but I really did not know it was not supposed to work this way. Now the machine is over a year old. I will be calling tomorrow and complaining but am not very optimistic that they will do anything and from what I have been reading will NEVER buy another one!
Sep 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I am comparing Shark steam mop and H2O steam cleaner. Which would you reccommend?
Judge from the volume of helps I see here I would get the H2O.
heatman101
Jun 23, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Shark 3501 has a broken handle above the resevoir. Called Euro pro and stayed on hold for 25 min with no answer. I am looking for a handle from top down to tank. Can you help?
No, you need to call them... check the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
H2o TR220002 Steam Cleaner Logo
19 people viewed this question
Top H2o Vacuums Experts
rugby prop
Lawrence Oravetz
Tom Chichester
Are you a H2o Vacuum Expert? Answer questions, earn points and help others
