Question about Air Tools & Compressors
Mastercraft compressor 820250
Tipped over now leaking air and won't fill
4 Suggested Answers
  • 1388 Answers
SOURCE: Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
Posted on Aug 01, 2010
miket756
  • 2702 Answers
SOURCE: How are the valve plates seated on an 8 gallon
the velves are called "reed velves" look from under the head at the velve block as if you were the piston, as the piston gos down it pulls (open)the inlet velve (but the out let velve is held closed by spring presher) and on the way up it (pushes closed on the inlet velve) and pushes the out let velve open so air can be pushed into the air tank,,,has this helped you? they are held in place by light spring presher and maybe fasend by a bolt?
Posted on Oct 25, 2009
  • 1015 Answers
SOURCE: mastercraft model#820250 air compressor only
I think you are going to need to replace your regulator.I think true value and ace hardware handle mastercraft so you can give them a try for parts.
Posted on Aug 29, 2011
I have a mastercraft compressor with LCD display its 11 gallon,it runs up to about 70 psi and will not go higher but keeps running, any ideas.
You either have an air leak somewhere or you have a damaged valve in the valve body. You can check for leaks using a spray bottle with a dishwashing detergent/water mix. Spray the mixture on connectors and look for bubbles. Don't forget to check the tubing coming from the compressor head and the regulator. If you find no leaks (you need to check carefully), you might need to remove the compressor head and check to see if the valves in the valve body are damaged. My Campbell-Hausfeld compressor did the same thing and I had to replace the valve body.
Mar 08, 2017 | Psi Air Tools & Compressors
I need the 2 head gaskets for a mastercraft compressor # 820250 and the torque for the 4 bolts.
Check out this link.
http://r.search.yahoo.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--/RV=2/RE=1461669297/RO=10/RU=http%3a%2f%2fpixel.everesttech.net%2f2966%2fcq%3fev_sid%3d105%26ev_ltx%3d%26ev_lx%3d298039750111%26ev_crx%3d31577062116%26ev_mt%3dp%26ev_dvc%3dc%26url%3dhttp%253A%2f%2fwww.grainger.com%2fsearch%253FsearchQuery%253Dcompressor%252Bparts%2526cm_mmc%253DPPC%3a%252BYahoo%252BMain%252B13-_-Pneumatics%25253EAir%252BCompressor%252BAccessories%25253EBMM-_-adgroup-_-keyword%2526adgrpID%253D8908786725%2526kwdID%253Dcompressor%2bparts%2526s_kwcid%253DAL%25212966%252110%252131577062116%2521298039750111/RK=0/RS=fPZSs20XF4VDzdFskDHPgQls9JA-;_ylt=AwrEWDYx3R5X2AcAzIJXNyoA;_ylu=X3oDMTE2OHJnaXZxBGNvbG8DYmYxBHBvcwMzBHZ0aWQDQjE3OTNfMQRzZWMDb3YtdG9w;_ylc=X3IDMgRydAMx?p=820250+mastercraft+compressor+parts
this might help out
Apr 24, 2016 | Cars & Trucks
How do i find parts for my mastercraft model no:NS563 air compressor?
I find nothing for Mastercraft but boats.
I suspect your compressor is a common (Chinese) manufactured compressor as most. Probably uses common parts. If you know what part you need I'd search the www for local parts reseller (like Granger see link below) and take the part in. Grainger Industrial Supply MRO Products Equipment Tools
Bill, sells a book, but also has a good troubleshooting guide. Troubleshooting Your Compressor
Jan 19, 2015 | Air Tools & Compressors
Mastercraft air compressor parts
just get some ptfe tape from and plumbing shop and wrap the plug
May 19, 2014 | Air Tools & Compressors
What's wrong with my oiless air compressor
Sounds like the reed valve or valves in the head failed. When you unbolt the head you will see a thin piece of metal that is the valve assembly. If it is not all one piece it is broken and needs to be replaced.
Apr 25, 2014 | Garden
Mastercraft 5 gallon compressor
you can try replacing the seals first but i would recommend rebuilding the valve
Jan 23, 2014 | Garden
My mastercraft aircompressor kit runs good but does not hold air
Check for leak through any of the sources in the tank , if so there will be no collection, you must observe for air noise hiss to identify the place of leak.Plug all the leaks and try, check on drain taps, pressure cut off switches or any leak on the tank.
Mar 14, 2012 | Air Tools & Compressors
Mastercraft model#820250 air compressor only goes to 50psi won't shut off (no air leaks)
Aug 29, 2011 | Garden
Mastercraft 2.0 hp air compressor will not build up over 25 psi
sounds like a bad or broken valves in the head. crankcase needs a vent which is sometimes a small hole drilled into the oil fill plug and will normally blow some air out the vent while it runs
Mar 22, 2009 | Air Tools & Compressors
Dewalt compressor not filling with air
if you do not have any air leaks and it is a oil less compressor than it is most likely the piston seal is wore out. if it is an oil compressor that it is likely a flapper valve
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Air Tools & Compressors Logo
372 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
