Question about Dishwashers
I want to replace the spray arm assembly #WD22X154 on my GE dishwasher. How do I remove the existing spray arm assembly? The Dishwasher is Model# GSD2600G02BB. Thaks, Bill
  • riverview375 Apr 23, 2009
    Is the threaded base standard right hand thread?
    thanks.
  • 3,361 Answers
Grasp the base of the spray arm and twist it to unscrew. May need large pliers.
Posted on Apr 23, 2009
  • steve
    steve Apr 23, 2009
    Yes.
Dishwasher won't drain
Make sure the hose is looped higher than the sink drain before it goes into the Y connection of the drain. This helps the syphon effect and prevents the sink water from draining into the dishwasher.
Feb 14, 2016 | GE Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Dishwasher will not drain all the water out
If this is a GE or Hotpoint dishwasher the solution is fairly easy, but a pain. GE (Hotpoint is the same company) has been using a small plastic ball that prevents backflow of the water. A lot of times that ball migrates and doesn't allow the dishwasher to drain. To get to this, you need to remove the two 1/4 inch hex head screws in the food trap basket, the 1/4 inch hex head screw from the spray arm, and use a small screwdriver to pry a clip at the back of the spray arm up to remove the spray arm assembly. Siphon as much water from the dishwasher as possible because you'll be opening up the plumbing below. Turn off your electricity to the dishwasher and pull it out of the cavity. Directly behind the motor is a large manilla-colored "tank" with a large hoseclamp holding a white union with two smaller hoses coming off it. Loosen and remove the white union from the large tank and the ball should fall out. Replace the white union, tightening the hose clamp and drop the ball back into the tube on the left side of the food trap basket. Put it back together and test run.
Sep 10, 2009 | Dishwashers
The diswasher arm does not rotate or spray water
Check the small holes on the spray arm. They are most likely plugged. (candy wrappers, tooth picks, popcorn or watermelon seeds, you name it.) Sometimes you can clear the holes out, other times it is just as easy (and not very expensive) to replace the spray arm(s). List your model number if you need part numbers or instructions on removing spray arm.
May 14, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwashers Logo
229 people viewed this question
Top Dishwashers Experts
