Question about Smeg FAB310X Top Freezer Refrigerator
My miele 7081 432-00 fridge keeps icing up - Smeg FAB310X Top Freezer Refrigerator
I have got miele fridge freezer but the fridge keep freezing what can I do
Usually a faulty temp sensor on the fridge evaporator, not an easy repair for most, I would personally recommend Miele's fix priced repairs
Service Repair Miele Support Miele UK
Sep 19, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
My Miele KFN12924SD fridge is not getting cold
Known problem with this model (and similar) after 2.5 years - look around the internet. Ice forms within, at back - and Miele can't repair. Yes, crazy - just tell them it is their design fault, and so by law they have to replace.
Mar 25, 2013 | Miele KFN8462S Bottom Freezer Refrigerator
KFN 8862SD Fridge /Freezer The above unit is constantly building up ice on the fridge rear panel, despite having auto defrost! Help!!
1st stick a rag in the hole in the door (ice maker door) 99% of the time or o door gasket .... next ohm the auto frost coils to see if there in good working order, if they are it might be that you are low of freon. not a good sign
Jun 06, 2011 | Miele Freezers
Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Jul 24, 2010 | Miele KFN8762SDED Bottom Freezer...
My Miele frost free fridge freezer is accumulating ice and water below the two trays in the fridge. What to do, please?
Call Service. 1-800-999-1360 (US) or the Canadian number. Most likely the circulation fan and/or damper flap could be out of whack.
Jul 12, 2010 | Miele Refrigerators
The fridge section of my Miele fridge/freezer keeps freezing all my food! I put it on 'holiday mode' to defrost and within 24 hours of turning on again it has frozen up.i don't hear the motor switching off...
You require NTC for fridge evaporator. Part no.7323301. It is the one screwed to the back wall of the fridge with a green band on it.Behind the cover at the rear of the light.
May 13, 2010 | Miele KFN8762SDED Bottom Freezer...
Miele fridge too cold
Hi I have the same problem...did you find the solution?
Jul 18, 2009 | Refrigerators
Smeg FAB310X Top Freezer Refrigerator Logo
114 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
