Question about Sewing Machines
I have a singer Esteem 2 model 2273. It is brand new. The feed dogs move up and down when the needle moves but it won't feed the fabric through. It just sews in place.
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
louislevel_2
  • 374 Answers
SOURCE: Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Posted on Mar 19, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
SOURCE: Kenmore sewing machine # 385.17626
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Posted on Aug 18, 2009
  • 109 Answers
SOURCE: feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Posted on Aug 23, 2010
Feeddog singer stylist 776 how would the feeddog gt lowered
Consult the owner's manual. There should be instructions for how to darn with your machine. It would require either the feature that lowers/raises the feed dogs or a cover plate that attaches over the feed dogs.
If your machine came with the cover plate accessory, and the feed dogs are not rising to feed the fabric, then I suspect the machine has not been cleaned & oiled in quite some time and perhaps the feed dogs have seized. When you run the machine (remove the needle and presser foot), watch if the feed dogs actually drop below the needle plate, move toward the front of the machine, then rise above the needle plate and move toward the back of the machine. This is a repetitive motion that actually pulls the fabric through the machine. If this is not happening with your machine, it needs service.
Singer Stylist 776 Manual Page 8
Oct 30, 2016 | Singer Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
My fabric dosnt move foward or back wards with the petal or manually ..
if the fabric won't move then there is something wrong with the
feed dogs, check in the needle plate to see if you can see the feed
dogs. you should be able to see them & touch them with your finger
since they are not moving the fabric it would be a good idea to
have the machine checked
I'm putting a link for a free manual for the machine, you can check
in the manual to see if it show where the feed dog lever is on the
machine, if it doesn't show a lever, or the lever is not responding to
movement then the machine needs to be checked to see what's
wrong.
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Sep 04, 2012 | Singer 2932 Mechanical Sewing Machine
I have a singer 3343c machine, when sewing the fabric foot does not move, the fabric while the machine is sewing.
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
Dec 10, 2010 | Singer 3343 Mechanical Sewing Machine
I have a singer model #2932 It will not advance the fabric, just keeps sewing in the same place
I've been sewing since I was six (with mom's help), but all sewing machines are basically the same. The feed dog, which is what advances the fabric is most likely not moving. If you look at the area just under the presser foot & needle you'll see little "teeth". This is the feed dog. Take the thread out of the needle and run the machine without any fabric. Watch those teeth. They should rise & lower into the base. If they don't move when the foot pedal is pressed, then that is your problem and you'll need to take it to a repair shop. Good luck.
Nov 06, 2010 | Singer Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
