Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0 •Ovens: Fan oven •Timer: Minute Minder •Hob: 4 Burner Gas Hob •Colour: Stainless steel •Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
