How to replace bulb in crosslee cheltenham electric fire
Replacing bulb in dimplex electric fire chb20br
To replace the bulbs, your will need to remove the plexiglass front, then remove the logs and set them off to side where they won't get stepped on. Then lift up the plastic simulated ember bed. You now have access to the light bulbs. The required bulbs are 60 watt small base chandelier bulbs.
Hope this helped you, Margo. Thanks for choosing FixYa.
Aug 18, 2011 | Heating & Cooling
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 | Dryers
Crosslee plc is an appliances company formed from the tumble dryer division of Philips. Its best known products are White Knight brand tumble dryers. The company is based in Halifax, West Yorkshire, England.
here is ther main webpage:
Try contacting them thru e-mail about getting manual most company's will give a copy/or post one on their website for free.
good luck
Aug 04, 2009 | Dryers
Rotary dimmer control for 5 light chandelier stops dimming
Whoa...You definitely may have a fire and/or shock hazard hanging from your ceiling. I've seen a lot of fixtures with old, brittle wire and bad insulation in them. Lamp wiring is subjected to a lot of heat, especially with higher-wattage fixtures. Long term exposure to heat near or above the insulation's rating is especially damaging to electrical insulation. I've also seen cases where metal parts of the bulb socket partially melted and/or broke loose.
If you're comfortable and confident of your abilities to make a safe electrical connection, you can replace the wire and bulb sockets in your fixture. If it's valuable or an attractive antique, it's worth fixing or having fixed, even if you sell it. Just make sure you use wire with insulation rated for use in an electrical fixture. It must be rated for a temperature no less than 105 degrees Celsius.
It it's a lower cost fixture, replace it or have it replaced. Regardless of what you do, you're probably going to be replacing that dimmer again...sorry.
If you live in an older home, it may be worth (in terms of safety) having a few qualified electricians evaluate your electrical system as a whole to make sure everything is still in safe condition.
May 04, 2009 | Rotary Lot 10 Leviton Ivory Light Dimmer...
Replace light bulb in a Charmglow electric fireplace
you have to remove the doors and then the lower ember cover, he lighs are underneath.... i am looking on how o make he flame move, it froze and won look like real fire anymore
Oct 21, 2008 | Kitchen Appliances - Others
Position of coals on a gas fire
Hi crosslee are on google they have a e-mail help line they should be able to send a pic of how the coals should go ,
Sep 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
