Question about Miele S7210 Bagged Upright Vacuum
My s7210 has jammed so wont stand upright ,the foot which lets it release also jammed .what do i do to ?
2 Suggested Answers
small6363
  • 18424 Answers
SOURCE: Miele S7210 upright how do I remove a split hose from the handle end
THIS LINK IS THE MANUAL
http://www.totalvac.com/manuals/miele-vacuum-S7000-manual.pdf
Posted on Oct 16, 2012
The hose is blocked, how do I get it off to unblock?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the hose to start unblocking it, do the following:
1. Put the vacuum in the upright position
2. Press the release button of the telescopic wand and remove the handle from the hose
3. Push the hose elbow downward into the catch hooks.
4. Undo the suction hose by twisting it at the elbow.
If the blockage isn't in this location you can do the following to search further for blockages:
5. Open the service flap on the back of the vacuum.
6. Unscrew the screws and pull the cover free.
Below I have attached a link to the users manual for the Miele S7210. You should refer to page 30 to view the diagrams pertaining to my suggestions.
http://www.sylvane.com/media/documents/products/miele-s7210-twist-upright-vacuum-users-manual.pdf
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Oct 14, 2015 | Miele S7210 Bagged Upright Vacuum
Bissell wont stand upright
These machines are famous for braking the foot pedal release lever. It is replaceable.
Sep 04, 2014 | Bissell Vacuums
Milie won,t stay upright
If your miele is laying all the way down like mine is and will not stand upright..look for a dark gray corrugated plastic part where the handle bends at the base. This is above the silver holed plastic filter holder. This may be stuck. I just pulled mine out and then I was able to stand it upright again. I wasn't able to put it back in but I think it is there just to cover up the inside workings of the vacuum. So I left it out.
May 23, 2014 | Miele S7210 Bagged Upright Vacuum
I have a miele upright S7210 and can not find the replacement hose. Any ideas?
What do you mean by the replacement hose? The original part for your 7210 twist includes the handle grip to lock in to the adjustable wand, or do you mean the short hose in the base behind the brush roll?
Sep 03, 2012 | Miele S7210 Bagged Upright Vacuum
On the first day of getting my new Miele vacuum it started making a clunking noise. It was after I tried doing the stairs which is very hard to do because the it is so heavy. How do I solve this noise...
Is the "clunking noise" when right after depressing the handle release lever? Also your Meile has a 39 foot cleaning radius to cleaning the stairs should not be difficult, unless you're picking the vacuum up and using the brush roll. They make a turbine tool the attaches to the hose end that is fantastic and makes these hard areas easier.
May 16, 2011 | Miele S7210 Bagged Upright Vacuum
I'm trying to get my S7000 Miele to stand upright an lock in this position. It wont , i tried to see if foot release was jammed but cant tell it doesnt seem to release to let it move upright an lock in...
There is a rear dust cover that sometimes gets stuck, this will make it almost impossible to lock the handle up. First locate the cover which is at the rear right above the wheels. It's about 2"x8" and ribbed vertically and slides up behind the rear panel of the lower body. If it's in there and stuck, just realign it with the 2 grooves on each side or remove it completely; it is a dust shield after all. The best fix is to replace the rear panel and dust shield and they are ordered together and the cost is fairly low. Also check the alignment of the rear body panel at the bottom There are 2 tabs that protrude down about and inch on each side, the one closest to the handle release lever sometimes gets bent and causes the unit to jam. If this does not help there is one more solution involving the rear wheel assembly. check to see that the rear wheel axel is straight, meaning both wheels are parallel at all times while releasing the handle. If the axel is crooked, the wheel assembly must be replaced and you should have a Miele service center order the part and do it for you.
May 01, 2011 | Miele S7210 Bagged Upright Vacuum
My hoover wind tunnel self propelled vacuum wont stand up be itself. The locking thing is not working. Thank You. niblick43@yahoo.com
If you look at the foot pedal, see if it is locked in the base, and pivots freely. I have seen some of these that break the base, or break the spring hinge on the back side of the release pedal.
Mar 10, 2010 | Hoover U5753-900 WindTunnel Bagless...
Hi, pressing the big red foot button on the dc25 lowers the cleaner to the working position,but it wont stand up again. would appreciate some help. thanks. TC
sounds like the ball cradle is worn out, the springs are too stretched to pull the handle release pedal back into place. you can do one of two things, replace the cradle assy, or just lift the red pedal up when you raise the handle
Feb 27, 2010 | Dyson DC25 All Floors Bagless Upright...
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Miele S7210 Bagged Upright Vacuum Logo
22 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
