Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How to install deck engagement cable on craftsman model 247.2888851
  • 7 Answers
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Posted on Sep 05, 2008
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
I need to replace the deck engagement cable.
Craftsman Mower Deck Engagement Cable install - YouTube
? 6:26
www.youtube.com/watch?v=q6cKjePhdqw
Jun 27, 2013 - Uploaded by redneckcomputergeak How-to install a cable engagement on a craftsman lawn tractor. Craftsman, Poulan, AYP, Husqvarna part 175067, 169676 Deckclutch cable with ... seat, but other than that the video was a HUGE help in replacing that cable.
Sep 25, 2015 | Garden
Have model 247.288811 and blades won't engage when the lever is moved forward. Lever feels like nothing is attached.
Most likely either your deck engagement cable is broken or has came the idler pulley.
Cable PN 946-04173E
May 17, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model 917270810 sn 050498D01879 blade engaging linkage on deck
Don't know exactly what your needing but is a link where can look at the parts list for your mower deck and engagement components.
CRAFTSMAN Tractor Mower deck Parts Model 917270810
Oct 19, 2014 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Craftsman lt2000
Your blades engage with a cable and the cable somewhere is bunched up. You will probably need a new cable.
Aug 05, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
A cable is loose that will not allow me to engage the blades, how do I reattach the cable. it is a craftsman Lt 1000 17 IC ohv . model # 917.272260 42 inch cut.
Tightening up a stretched cable is impossible. If the cable is NOT adjustable to shorten it and make it tighter, then you will need a new one. Here is a link to one. I searched all the parts diagrams in your manual for the cable and find it was NOT listed. I hope this helps as I have researched your problem. Go here:
http://amcpartsstore.com/FSP-Deck-Blade-Engage-Cable-Craftsman/M/B0014G6T1S.htm
Aug 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where do attach cable that engages blades
On a lot of Craftsman decks that are cable operated, the right side idler pulley is the tensioning pulley and at the top of the bolt that holds it in place is a hole for a retaining clip. With clip removed, slide the cable end over the post and install the clip. The cable will be kinda loose with the blades disengaged, but it will not come off. By the way make sure that the cable is routed through the holder towards the back of the deck and is properly secured.
Jul 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch deck won't run
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
