Question about Driving Comfort BonAire Ultimate Hose Nozzle
I just purchased the Ultimate hose nozzle at a home show and it doesn't work like the demonstration. It barley has a spray coming out. what could be the problem?
Washer fluid does not work on right side but left side barley spray at all
Could be a blocked hose. Try getting a needle, and inserting it carefully into the nozzle hole(s), be careful not to go too far in and don't change the adjustment/ angle of the spritzer itself.
Oct 05, 2015 | Cars & Trucks
Spray not working, doesn't stop water from faucet.
It sounds like a kinked hose under the sink or a clogged nozzle. Unscrew the nozzle from the sprayer and check for calcium buildup. New parts can be purchased cheaply from the local hardware store, take the old parts in and a sales rep can help you with the correct parts. Some sprayers have replacement nozzles...unscrew the old and screw in the new.
Sep 20, 2015 | Plumbing
How do i replace wind sheild washer spray nozzles ?
make sure you have washer fluid come out of the pump when on,if so maybe clogged hose to nozzle or nozzle clogged up which you can clean chemical residues with a sharp needle then moderately blow air(with air hose) from nozzle towards end of hose that connects to pump. Hope this helps. Oh,make sure not to wiggle the nozzle because then it would change direction of spray.
Jan 01, 2014 | 1995 Chevrolet Tahoe
Why can't we get the nozzle to move?
If you need a replacement part that includes a functional nozzle, you can purchase it here http://www.ebay.com/itm/Intelliseat-AMDM-ISB-200-body-Replacement-/222019823660?hash=item33b169a82c:g:v8QAAOSwzgRWvLSS
Aug 27, 2013 | AMDM Intelliseat - The Ultimate Bidet...
How to remove windshield washer pump
sounds like the spray nozzles are clogged you can usually remove them and soak them in soapy water or spray water through it with a sprayer on the end of a hose. if that doesn't solve it then you may have a cracked line or the pump that pumps it out may be broken but usually is the nozzles are clogged.
Sep 23, 2012 | 2002 Pontiac Bonneville
Where can i buy repair parts?
Find a pressure washer vender in the yellow pages. It doesn't have to be a karcher dealer. Take it to them and show them what you are trying to accomplish. They can usually set you up with generic parts that will work just as well or better. Parts like hoses, trigger guns, lances, spray nozzles etc are really generic anyway. That's why there are no part numbers.
Also, stores like Home Depot, Lowes, Sears etc usually maintain a small section with these generic bits n pieces. I hope this is helpful to you and gets you pointed in the right direction! And good luck! Rate me if it has helped you. Thanks!
Don
Mar 04, 2012 | Garden
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
Rear window washer does not spray fluid. When I push the rear window washer button, the front washer/wipers turn on. The rear wipers work normally.
I have the same problem with my 2000 chevy blazer as skornec had posted. I kinda already figured the hose or spray nozzle was plugged. But the problem with checking those items is that I don't know where the hose is located to the back wiper. And the only thing that could be I see that could be the spray nozzle doesn't even have holes that washer fluid could spray from. So basically I just would LOVE if someone could please inform this lame brain of where to find the spray nozzle on the rear window and where in the interior of my blazer does the washer hose run.
Apr 02, 2010 | 2000 Hyundai Accent
Driver's side windshield washer will not work.
Probably not frozen or both sides would not work. Remove the hose where it attaches to the spray nozzle. Try the pump again. If solution comes out then all you need to do is unplug the spray nozzle. Hook the hose back up. Use a very small pin that you can place into the spray nozzle hole. Gently insert it in to the spray nozzle and work it around a little. Try the pump again and you should get solution flowing again.
Feb 04, 2009 | 2006 Ford F-150
Driving Comfort BonAire Ultimate Hose Nozzle Logo
61 people viewed this question
Top Driving Comfort Garden Experts
Dennis Key
Dennis Key
john h
Are you a Driving Comfort Garden Expert? Answer questions, earn points and help others
