Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C stuck in "please wait maintenance"
The machine has the message "please wait maintenance". Switching on-off does not help to reset, nothing is working. What does the message mean?
  • 832 Answers
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Posted on Sep 24, 2007
  • Mix-it-up
    Mix-it-up Sep 28, 2007
    AF means that the scanner flatcable isnt connected. Check connection to pcb. Flatcable must be in good position (simply stick it onto the pcb).
SOURCE:
"Unable to clean" error message on Brother MFC 210C all-in-one printer.
reset the printer by leaving it unplugged for at least 2 hours and then boot it back up. this will flash the memory of the machine
Sep 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C with error code 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C All-In-One InkJet Printer ERROR 4F
This will reset the purge count value. Then restart you printer.
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210c
press menu then start bc copy then 4 times arrow up. What error code does the machine display.
Dec 12, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,085 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
