Question about Sony ICD-MX20 Digital Voice Recorder
Sony b120 .how to fast forward in a folder - Sony ICD-MX20 Digital Voice Recorder
I would like some advice on how to fix my sony tc161sd cassette recorder that does not play or fast forward
The unit needs belts and lubrication as well as other things that are seen in the repair of this older mechanism.
Oct 12, 2016 | Sony Audio Players & Recorders
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
IC B120 VOICE RECORDER
Do you mean a Sony ICD-B120? If so you may download a copy of the manual here.
Jul 17, 2012 | Audio Players & Recorders
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
I have a VGN-CS118E and it's media touch buttons don't work, only the AV button works
The touch sensor buttons that control the AV Mode, volume, play, fast forward, etc. may stop working if the Synaptics Pointing Driver is uninstalled or if the file is corrupted. Follow this procedure to reinstall the Synaptics Pointing Driver.
Downloading and installing the Synaptics driver update available through the below link on this page will also resolve this issue.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS118E&upd_id=3783&os_id=28
After installing, reset the BIOS to its default values.
Click the Start button, and then click on Computer .
In the Computer window, under Hard Disk Drives , double-click on (C:) .
Double-click the Windows folder.
Double-click the DRIVERS folder.
Double-click the .EXE folder.
Double-click the Pointing Driver (Synaptics) folder
Double-click on the setup or setup.exe icon.
Follow the Synaptics Pointing Driver Installation wizard instructions to install the driver.
When the installation setup is complete, a You must restart your computer to apply these changes window will appear. Choose the Restart Now button for proper installation .
Thanks!!!!
Dec 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Where can I download Sony ICD-B120 Digital Recorder Manual?
You can download the operating instructions here:
http://www.docs.sony.com/release/ICDB120.pdf
Dec 07, 2009 | Sony ICD-B120 Digital Voice Recorder
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
Fast forward
At first set factory settings and format your phone. If not work you need to reflash the phone.
May 19, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Fast forwarding
I would set index marks if you need to get to a specific part. I am not sure if that's what you are trying to do. (not sure about changing folders - you always need to be in the folder where your files are) Check video manual on Olympus 4100PC at www.HandBookLive.com under Electronics category. There are chapters on setting index marks (scroll to the end of the video chapters)
Oct 13, 2007 | Olympus VN-2100PC Digital Voice Recorder
Sony ICD-MX20 Digital Voice Recorder Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
