Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool Refrigerator Model ED5FHAXVS Side By Side "Not Cooling"
The unit is not cooling on the Fridge side only. Temperature control has been adjusted and problem still persist? Any ideas on how to troubleshoot? I noticed a vent in the upper left hand corner and feel no cold air flowing?
  • Samuel Charles Spriggs May 11, 2010
    There is a temperature controlled actuator for the door which lets cold air out of the freezer. This could be stuck or caked with ice. I believe you'll find it somewhere in the back of the freezer compartment -- it's probably accessible without removing the rear wall of the freezer.
    Let me know if you can find this?
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator is not cold and my freezer is too cold and i have adjusted the temperature dial
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Model GS5SHA Side by side. Freezer working, refrigerator side not getting cold.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
I have a Whirlpool fridge freezer ART 731. The freezer is working fine but the fridge has started to get too cold and freeze the items inside although the control is at its lowest.
heatman101
Aug 27, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool side by side not cooling
check behin the fridge. try listen the compressor. not hear the com.? maybe time for a new fridge. unless is under full warranty
Mar 31, 2010 | Whirlpool ED5GTNXMQ Side by Side...
Fridge not cooling/frezer overworking
It is constantly running because the thermostat in your refrigerator registers a warm temperature that never reaches target. Your refrigerator's cooling is dependant on your freezer - obviously your evaporator fan is working since your freezer is cooling, however that cool air is, for some reason not reaching your fridge - Make sure the vents are not blocked or plugged with ice - If applicable also check the damper, maybe the flap is not opening at all, letting cool air in.
Also check door seals and make sure te light switches off by pressing the door contact button.
Sep 26, 2009 | Whirlpool ED2FHGX Side by Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Whirpool side by side refrigerator ,fridges is not cooling at all
HI.YOU MIGHT WANT TO CHECK IF THE FAN IS WORKING WELL OR IF THE UNIT IS NOT OVER FREEZING WHICH CAN E A CAUSE OF THE FRIDGE NOT COOLING PROPERLY.FEEL FREE TO REQUEST MORE ADVICE IF NEEDED
Nov 13, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
509 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
