Question about Pentel Twist-Erase QE515 0.5mm Automatic Mechanical Pencil, BLK
How to load lead into Pentel QE515 pencil - Pentel Twist-Erase QE515 0.5mm Automatic Mechanical Pencil, BLK
How to remove lead pencil from the sole
to start with , there is no lead in a pencil
It is graphite
so to remove graphite use a suitable cleaner
Dec 09, 2016 | Cars & Trucks
How do you replace the lead in a Pentel graph gear 1000 pencil 0.3
By removing the rubber and dropping the new lead into the pencil body. But what this has to do with Motorcycles is beyond me
Dec 20, 2014 | Motorcycles
How do I change the pencil lead in an M & G MP-3290 mechanical pencil?
press the pencil lead dispensor button... (the one you press when you want more lead to protrude).
turn the exit point UP and insert new lead.
turn right side up and write away!I too love the mechanical pencils
Apr 14, 2013 | Cars & Trucks
How do you load a new lead?
To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size. 2. Remove the plastic cap that covers the eraser on the end of the pencil. 3. With the cap removed, gently tug the eraser out of the end. 4. When the eraser is removed, place a few pieces of lead into the open tube. 5. Insert the eraser. 6. Replace the cap on the end of the pencil. 7. Depress the end of the pencil a few times to feed the lead through the tip. 8. Write!
Mar 10, 2011 | Zebra Z Grip Mechanical Pencil, 0.7mm...
How to fix a cross pencil
cross revere pencil lead falls out...Mabe I am not loading. Load from top or at poing. First time repacement has been reqired
dale Taylor daleworth@gmail.com
Dec 24, 2010 | Sewing Machines
How do I refill the lead in a pentel twist erase pencil
Open the pencil in the middle, like pulling it into apart, then load the lead from there.
Sep 02, 2010 | Office Equipment & Supplies
I am trying to determine what cpu pentel 4 (D) 3.0
Gateway 831GM Pentel 4(D) is for socket 775
Jul 25, 2010 | Gateway 831GM PC Desktop
Pentel Twist-Erase QE515 0.5mm Automatic Mechanical Pencil, BLK Logo
46 people viewed this question
Top Pentel Office Equipment & Supplies Experts
k24674
Are you a Pentel Office Equipment and Supply Expert? Answer questions, earn points and help others
