Question about Horizon AFG 3.0 AT Treadmill
Center running belt horizon CT7.1 treadmill - Horizon AFG 3.0 AT Treadmill
  • 14 Answers
SOURCE: i have a horizon t92 treadmill. my problem is with
Loosen rear tension and recent and tighten.
First grab the walking belt on an edge and lift up, It should only lift up 3 inches, this about the right tension
There are two guides underneath near the front make sure the belt is underneath them. (they touch the white side)
If OKay, remove the endcap byu the tension control bolts (two screws underneath) and make sure you have adjustment room (threads showing on bolts toward the rear)
these bolts should look about the same position with respect to the roller.
Run the machine on slow, walk on it and try to stop the walking belt, if it slips - turn both rear bolts 1 turn clockwise.,repeat until it doesn't slip
Get off and run the machine on slow 2mph, turn the bolt on the side the belt wanders to 1/4 turn clockwise. If it goes over fast you may need turn the bolt 1 full turn right away (it shouldn't). If its kinda of stable - speed up machine to 5-6 and repeat.
Note the front of the belt should be centered first, this is preset and usually doesn't need adjustment
Posted on Aug 22, 2009
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
2manyhobbies
  • 128 Answers
SOURCE: LOOKING TO BUY A MAGNETIC
Contact Horizon Fitness at 1-800-244-4192 for customer service.
Parts can also be obtained from the Treadmill Dr., and Fitness Repair Parts..
Posted on Dec 15, 2010
SOURCE: horizon treadmill won't start running
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a horizon t73. Best treadmill ever but it now wont start. It turns on, electrical works, sounds like it going to run but the belt doesnt move. any ideas?
Dear Sir:
1) Tight the deck belt see the diagram 2) Lube the deck belt in according with the instruction manual maintenance. 3) Test the drive belt and replace it 4) Measure the input voltage for the main motor if there are the motor need repair or replace 5) Test the output voltage from the main motor board if there are NOT the board is faulty.
Posted on May 03, 2012
How to center walking belt?
Most treadmill belt adjustments are controlled by the bolts on the back of the machine on either side of track rails. Loosen opposite side of track while running and the track will move over and tighten when in desired spot. Be care not to have it running to fast or the belt will quickly move to far over. Running for a few minutes on hire speeds after adjustments are complete to make sure belt is not in need of fine tuning.
Jul 19, 2014 | Horizon Fitness T202 Treadmill - Sport...
Belt is loose and too far to the right
The side the belt is running to is the side you adjust first.
Turn the machine on to 2 kph.
Stand with 1 foot on the side rail
Try and stop the belt with the other.
If you can stop it tighten both sides 180 deg clockwise.
Repeat test until you can not stop the belt.
Now it is tight.
The rear roller has to be even to keep the belt from running to 1 side.
If you have turned 1 side more than the other the belt will run to the other side.
Hope this helps.
Dec 14, 2013 | Horizon Evolve SG Compact Treadmill
The T202 belt is not in the center
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Jan 21, 2013 | Horizon Academy Sports Fitness T202...
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
Dear Sir:
Apr 29, 2012 | Horizon Fitness T73 Treadmill - $1,299...
I have a Horizon fitness CST3 and the belt stops running but everything else stays on. Do you know what is cuasing my problem?
How old is your treadmill? Has the deck been lubricated? Do you smell anything odd when the belt stops? Unplug treadmill, remove motor cover and check cables are all connected.
Oct 23, 2010 | Horizon Fitness Merit Fitness 725T...
Display says LUBE
It is time to lubricate the running belt you may purchase this lubricant at your fitness specialty store or directly for Horizon their # is 1-800-244-4192. Here is a procedure you can follow and your owners manual should have the reset procedure after completing lubrication procedure, if not while ordering the lubricant ask Horizon for it.
LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
Mar 13, 2010 | Horizon Exercise & Fitness
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Horizon AFG  3.0 AT Treadmill Logo
37 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
