Question about Jabra GN9125 Wireless Headset
Caller can hear her but she can not hear caller through head set
I can't hear the caller but they can hear me what can cause this to happen
Hello Terry, Are you sure the other caller does not have their phone button set on MUTE? That would cause them to hear you but you can't hear them. Do you have the same problem from other callers? If so, it must be a problem with your phone.
Apr 10, 2015 | LG Straight TaL34C Optimus Fuel Android...
Can't hear caller on Skype
Check you settings in two places for the correct audio out settings:
1. Look up under the System Preferences menu (the Apple pull down menu) the sound icon (looks like a speaker) and click on it to open it. At the top it will show three choices, Sound Effect, Output, Input. The problem you can't hear the Skype caller is likely the Output setting is incorrect. For example, you may have Line Out selected, but you are listing on head phones. Make the device name match what you are using to make sound.
Also check to see that the output volume is not set too low. Move the slider around to increase the volume.
2. Then check your Skype setting.Under Skype>preferences, select Auto/Video. Check to see what is selected under "Speakers: and check again to see the Volume is turned up high enough to hear.
Also make sure you have a good speaker or headphone connection.
You can check to see if you can hear by calling the Skype test call number to record yourself and listen to it. Go the www.skype.com/go/help for more information.
Jan 23, 2014 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Have a LG_p509 android cell phone cant hear and the caller cant hear me
do factory settings press 2945#*# and then select factory settings this method will delete your all data so please first make backup, if this didnt solve the problem you need to give someone who repair hardware( maybe need to change speaker and mic).
Jun 19, 2012 | LG P509 Cell Phone
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
Other caller cant hear me but can when earphones are used
If a caller can not hear you when you talk directly on the phone and can only hear when you use your head set, then it is most likely that your phone's mouth piece is faulty or damaged.
You can try tapping it gently a few times, if this doesn't work, you might have to replace the mouth piece.
Thank you for using Fixya,
Kenneth
Feb 14, 2010 | Nokia 6300 Cellular Phone
Audio problem. my phone rings when i receive calls but can't hear the voice of the caller.
check if the volume has been set to low if not then add a head set to check if you can the hear the other party's voice
if yes then you may have to replace your ear piece in the phone
cheers
pls rate the solution
Jun 29, 2009 | Nokia N70 Cellular Phone
Sony ericsson phone
that happen to my phone,put your head phone in and see if ppl can hear you?
Jun 03, 2008 | Spec Research KW 580-I4 (KW-580I4) Serial...
Can't hear caller's voice
Turn up the volume control.  Don't have the manual in front of me but go into phone settings and look for the volume settings( not the ringer).  Check in your manual, you'll find it.
Oct 23, 2007 | Motorola Mobility L6 Cellular Phone
Jabra GN9125 Wireless Headset Logo
18 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
