Question about Sunbeam Gcsbcs-105 Iron, Turbo Steam Master Professional
Iron won't stop blinking red and beeping - Sunbeam Gcsbcs-105 Iron, Turbo Steam Master Professional
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Blinking red ready light
www.laundry.manualsonline.com has free manual
Mar 23, 2014 | Sunbeam GCSBCS-100 Turbo Steam Iron
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Beeping and error message
Your Iron has a faulty circuit board and need to be replaced
Jul 23, 2009 | Black & Decker D2030 Iron
Blinking red light
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Sep 06, 2008 | Irons
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Sunbeam Gcsbcs-105 Iron, Turbo Steam Master Professional Logo
37 people viewed this question
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Karl H
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
