Question about Magic Sing Along Consumer Microphone
I have a wow videoke premium model TKR 301 MR.. The two microphone is not working.. Pls. Help me to fix it! It's very hard for me to find a repair shop in Singapore ..by the way I bought it in Philippines 2 yrs ago :(
My mow videoke premium tkm-370p wo concerto pro 2 mic delay what to do?
HELLO KRIS if your batteries are ok
adjust from the main menu and make some test to check if your voice is not delaying
adjust the tempo from 9 left too slow from 9 to right faster
best regards antonio
Dec 29, 2013 | Audio Players & Recorders
My wow premium karaoke does not load
hell l your problem seems to be its out of FRECUENCY and is not aligned if you turn it on a lamp in the reception must lit
if it doesnt thats the problem of course the baterries are new right
your antonio
Dec 27, 2013 | Magic Sing Along Consumer Microphone
How do I hard reset my WOW Videoke Machine?
I don't know much about this device, but I do know that this company has a good service department. Send them an email at service@wowvideoke.com and they should be able to help you out.
Dec 20, 2013 | Magic Sing Along Consumer Microphone
Smart disk error 301
Anytime the Error 301 messages appear on your computer, it is due to corrupt or damaged system files.
If you do not fix this error immediately, it can lead to additional system issues, blue screens and hardware problems.
Frozen programs, installer errors, random shutdowns, system freezing and sluggish computer performance are common symptoms of the Error 301.
Fortunately, you can fix the Error 301 with features native to your computer.
Click "Start" and then "Computer." Right-click "C" and select "Properties."
Select the "Tools" tab and click "Check now." Select "Continue" if the User Account Control prompt displays.
Select the "Automatically Fix File System Errors" option and click "Start." Agree to reschedule the check for the next system restart.
Reboot your system.
Allow the check disk to detect and repair all Error 301 issues.
you should have no input while chkdsk utility is in progress any input might further damage your computer it might take some depending on the size of the disk be patient.
Hope this helps
Oct 28, 2012 | HP 500 GB SATA Hard Drive
Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Apr 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Hand microphone for DT 100 does not work. Need replacement mic
MR-9 Microphone for DT-1000
The MR-9 Microphone allows direct dictating to the DT-1000 Transcriber and also permits you to control the playback functions remotely. Remote playback functions include Listen, Fast Forward, Rewind, and Stop. Cord extends to approximately 6 feet.
http://www.olympusamerica.com/cpg_section/cpg_audio_acc.asp?val1=1&accessory=76
Jan 28, 2009 | Olympus Pearlcorder DT1000 Desktop...
Perfect score every time even when intentionally trying to do bad
The service center in California has the pack to upgrade (fix) the scoring in ET-13000 and most likely other models, including the ET-18000. They can be contacted at 1-714-578-0004.
I had mine upgraded by the place where I purchased it (MagicSingMall / www.magicsingmall.com) in New York (phone # to call is 1-212-561-5919). They might be able to repair units purchased elsewhere - give them a call to find out.
Good luck & God bless
Dec 22, 2008 | Magic Sing Along Consumer Microphone
Broken karaoke mic ed8000 model
Hi im joe,
if the screen says no font, no picture, no song data it means all the data installed was lost. you have to send it to the nearest service center to have it reprogram.
Feb 24, 2008 | Magic Sing Along Consumer Microphone
Magic Sing Along Consumer Microphone Logo
186 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
