Question about Fedders A6P09S2A Air Conditioner
Fan won't come on.
The fan seems to have stopped working on our Fedders a6p09s2a air conditioner. What are some of the tips we could check to repair? The condencer seems to be working but the fan doesn't come on to push the cold air.
    Guru:
  • 587 Answers
First shut the power off then pull the blower out and try to spin the wheel if it spins freely then check the capacitor look for any swelling or dents and unless you know how to check it out, some AC parts stores may check it for you, but a lot of people just replace it first before the motor (it costs less usually around $5.00) if it's ok then the motor is probably bad and would need to be replaced.
Posted on Apr 25, 2009
How often do i dump the water build up
depends on the humdy in the air. The more hundy the more you will but check it every 4-6 hours. It should have an auto cut off when it fulls up.
Jul 18, 2010 | Fedders A6P09S2A Air Conditioner
I have a fedders (piece of junk)3 1/2 ton 4 year old unit. It runs fine during the evening after it cools off, but during the day it constantly cuts off and on unless I am spraying it with water. As soon...
sounds like your compressor is overheating is the compressor sweating down the sides? If it is you may have an airflow problem clean filters, clean blower fan motor and the evaporator coil. if this does not work you will need to have someone put a set of manifold gauges on it to see if the proper pressures are where they need to be. Also you can check the amps on the compressor to see if it is sezing or if it is locking out. The compressor is getting to hot is the reason when you squirt water on it runs because you are cooling it down. have you cleaned the condensor coil? Your head and suction pressures will give you a good idea.
Jun 23, 2010 | Fedders A6P09S2A Air Conditioner
Air conditioner turns on then after a few minutes shuts of, shaking as it shuts off. then repeats
check you filter then you evaporator coil inside your furnance .....if that doesn't work your outside unit's coil needs to be cleaned
Jun 26, 2009 | Fedders A6P09S2A Air Conditioner
A/c won't blow any air
check the status of the blower, if it is not working than try to open the front panel of the ac and check the wiring of the fan......or else contact the service authority. i'm sure that there will be any lose connection or the wire is disconnected/cut..............have a nice day :-)
May 14, 2009 | Fedders A6P09S2A Air Conditioner
Need to replace seized fan motor
Fan motor has nothing to do with the refrigerant portion.
May 12, 2009 | Fedders A6P09S2A Air Conditioner
Replacement fan
please check the of fan , no of blades and direction of flow & also if possible pic of fan . it can be easily avl in open mkt.
ravi
Jan 31, 2008 | Fedders A6P09S2A Air Conditioner
Room air conditioner
Here is the link to the user manual; http://www.fedders.com/IandOResidential/Appliances/FedSglDualPort.pdf check page 6 first about timer controls and check there is nothing set there that may be stopping the fan. then check the fan hasnt been blocked or damaged, particularly by a damaged filter. Then the most likely problem would be a fault in the fan motor itself - sometimes these will have a thermal cutout switch which can be reset, or an electrical fuse. check for these if you fancy trying a repair yourself. If there is no cutout or fuse then a replacement motor would be probably worth it, although they can often be fixed, it is labour intensive and skilled so could be expensive. in the user manual are all the contact details for fedders dealers and repair facilities, also details of how to get spares (page 9). Hope this helps :)
Apr 03, 2007 | Fedders A6P09S2A Air Conditioner
Fedders A6P09S2A Air Conditioner Logo
160 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
