Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
KEEPS BLOWING FUSE ON CRAFTMAN 19.5 BRIGGS, WHEN TURN KEY TO START
  • 6 more comments
  • mike long Apr 23, 2009
    WILL NOT START OR TURN OVER, FUSE IS WIRED TO AMP GUAGE AND SELINOIED
    one wire from fuse to amp guage and the other is to starter side of
    selinoid
  • mike long Apr 24, 2009
    HOW CAN THEY BE IN CONTACT WITH STATOR ??
    ALSO WHAT IS A EASY WAY TO REMOVE FLYWHEEL ??
  • mike long Apr 28, 2009
    WHAT IF POSS. POST OF STARTER SPINS
  • Samuel Charles Spriggs May 11, 2010
    Look for a place where a bare spot on the wire could be touching the chasis. Sometimes this happens at the fuse holder. Let me know if you find anything. Also look on back of the ammeter to see if anything looks suspicious there.
    Well there is either a short or your magneto/alternator is overcharging. Trace the wire to/from the fuse. Look for a place where a bare spot on the wire could be touching the chasis. Sometimes this happens at the fuse holder.
    Please let me know what you find.
    thanks...
    Charlie
    Which fuse is this? Does the engine still run or does the blown fuse shut it down?
    Sniper:
  • 109 Answers
In my experience, and i have a good bit, when you turn the key and it always blows the fuse, the magnets under the flywheel are in direct contact with the stator (alternator). Both will need to be replaced...sorry
Posted on Apr 24, 2009
  • COUGHY_MAN Apr 25, 2009
    Under the flywheel there is a series of magnets, that is how it is able to produce the power to recharge the battery, sometimes, for no real reason, a magnet will break, causing all the others to break and short against the stator
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
2001 Mercury Mountaineer keeps blowing the PCM power diode (fuse #19)
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
Sep 18, 2008 | 2001 Mercury Mountaineer
K2500 Suburban with. 6.5 Diesel and the instrument fuse keeps blowing when I turn the key to the on position. When I disconnected the glow plug relay the fuse did not blow. Also while running with th
did u replace the relay just a curious question, sometimes they have rust and water in the inside of the relay but my guess would be that you have a bare wire rubbing somewhere, causing the fuse to blow, anything significant has happened before that issue?
Nov 25, 2013 | 1997 Chevrolet Suburban
20 amp fuse keeps blowing engine won't start, fuse
I am a mechanic,i had that same problem where my engine 20amp fuse were blowing....i fixed it...problem were a broken wire in the harnace on the side of the cylinder head....i made over $200 on that job...yahhh
Aug 01, 2011 | 2001 Mitsubishi Galant
Keeps blowing starter fuse when you turn the key to start engine.
YOU GOT A IGNITION WIRE TO STARTER SHORTING TO GROUND.
May 06, 2010 | 2000 Toyota Camry Solara
Ignition fuse keeps blowing when i turn the key
It MUST be the starter relay coil - or the power wire that feeds it. Likely a short in the relay coil (AKA starter selenoid).
Sep 15, 2009 | 2003 Saturn L-Series
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
Fuse keeps blowing
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Jun 17, 2009 | Garden
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
597 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
