Television I have a television antanna and the audio clarity is not what it was. I first thought that it was because of digital but some of the digital channels are clear and others are not. I was wondering how to fix it xince this is a new problem that just recently started? Thanks, Sam
  • 363 Answers
If the signal is degrading to the receiver then the sound or picture can start to break up. You may find that some channels were weak to start with, maybe because the antenna is not pointing directly at the broadcast transmitter. The signal may be degrading because of damp in the lead from the antenna, bad connections or atmosperic disturbances. High wind can misalign a loose antenna. Interference from other close by electronic devices may also affect the signal. My best solution is to first look at the direction the antenna is pointing and compare it with your digitally enabled neigbours. Then check that all the antenna leads into and out of your video recorder, digital reciever etc are good. Finally only a proper antenna install engineer will have the necassary equipment to diagnose the problem. If you haven't got one already then an engineer may recommend an antenna specifically for digital reception. Good luck and come back to comment soon! Regards
Posted on Sep 24, 2007
What audio out cord needed for proscan television.
Without a model number or picture I cannot tell you what you have available. That being said, you should have an audio left and right which will be RCA type connections. The other audio, not commonly used by home owners yet is the digital audio out. Either will work just fine.
Nov 29, 2015 | Proscan Televison & Video
We connected everything last night and the picture lacks clarity.
Is this a new television? You say you connected everything and it lacks clarity, are you saying you connected high definition devices (ie: Bluray player) and the picture is not in HD? Are you connecting thru HDMI? Sometimes it could be cables, could be that you are using A/V or S-video and the quality won't be as high. Are you connecting directly or thru an audio receiver? Need more information.
Sep 01, 2015 | Televison & Video
Sound balance is off
That TV has a lot of audio adjustments on it. Try changing the equalizer settings in the mid range. You may also want to see what it does when you hook something else to it and check the sound. If all else fails you can try the digital audio connection to see if that is clear. Otherwise you may to replace the audio board.
Jul 15, 2015 | Emerson LC320EM2 32" LCD HD Television
How do i get better clarity?
Set these picture settings.
Brighness=25 to 30%; Contrast = 60 to 70%; color=25 to 45% [according to your viewing taste]; Sharpness=20%.
Jul 04, 2012 | Insignia IS-LCDTV32 32 in. Television
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
After a power failure all our televisions dont have any signal
if your using an off-air antanna the or digital reciever box you may have to replace it. If you are using a powered antanae try plugging it in somewhere else if that doesn't work, you might have to buy a new powered antanna.
Feb 15, 2010 | LG 47LG60 LCD TV
Pip on d52w20
when i was on digital cable my pip didnt work either. with sat, the box offers a pip feature. if you have basic cable or using an antanna the pip on your tv should work. maybe its just your cable or sat not allowing you to use that feature.
Aug 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Viewing pictures on television
while recording the movies or taking photos just increase the pixel rate( to some 720 x ..) then you will see the good clarity in television ...
take the photos in the full capacity of ur mega pixels you will get very good clarity then....
Feb 11, 2008 | Fuji FinePix A820 Digital Camera
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
