Question about liftmaster Craftsman Garage Door Control Board 41a5021-1h-315
I have a craftsman 139.53663SRT2 it is working fine from the hard wire pad but all of a sudden the keypad and the car homelinks will not open/close the door?? Should I reprogram all of them, if that doesn't work what should be my next solution?
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Posted on Jun 19, 2009
handygirl911
  • 65 Answers
SOURCE: garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Posted on Jul 22, 2009
  • 8 Answers
SOURCE: how to reprogram whisper drive garage door opener
1)Press and release the "learn button" on the motor unit (the indicator light should glow steady for about 30 seconds
2)While the learn indicator light on the motor unit is glowing, press and hold the button on the remote unit you are using to open the door
3)When the motor unit's light starts to blink, release the button on the hand held remote. The motor unit has now learned the new code.
I hope this works for you!
Posted on Feb 12, 2010
  • 52 Answers
SOURCE: Liftmaster 1/2 HP Garage Door opener won't open or Close
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Posted on Feb 14, 2010
carmin77
  • 113 Answers
SOURCE: have a 2006 Liftmaster professional 1/2 h.p garage
The opener should have an antenna wire hanging out of it. Did someone/something hang on it?
Posted on Feb 26, 2011
Hi... I have a Sears Craftsman Garage door Opener Model# 139.53600 Outside garage door keypad which is hard wired (electric) isn't working. However the inside keypad and the car transmitter are both...
A wireless keypad will not work with your opener. Your opener is pretty old and the new models are much safer. You might consider replacing the entire thing.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have Craftsman garage door openers for both doors on our double car garage. The problem is with our keypad and our remotes in the cars. The keypad and car remotes work fine for one side of the garage,...
It sounds like the logic board has quit working on the one opener. If you have had lightning or power surges you might remove the logic board and check for loose, burnt or missing traces on the printed circuit.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
ALL OF A SUDDENT HE OUTDOOR KEYPAD NOT WORKING.
It could be the cold but it most likely is your keypad just failed.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can i program homelink with out a remote
The only way to program Homelink without a garage door opener remote is if you have a keypad that allows access to your garage. I tried EVERYTHING and then realized I had the keypad which is wireless; I simply unscrewed the battery operated keypad from its location and held it 1"-3" from the Homelink buttons in my car. I then punched in my code and held the enter button on the keypad at the same time as the Homelink button I wished to program. It worked flawlessly. Good Luck!!!!
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Craftsman Garage Door Control Board 41a5021-1h-315 Logo
60 people viewed this question
Top liftmaster Building Materials Experts
Terry Smith
Level 1 Expert
David Payne
David Payne
Glenn Mayer
Glenn Mayer
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
