My pc shuts down by itself
The computer turns off without any warning and when i switch it on, it doesn't turn on but the fan on the processor still runs. And sometimes it does turn on but it goes off when the O.S is about to load. Hi I'm having a very similar problem with a gigabyte GA-E45C-DS3R. My PSU is a Corsair HX520W.My CPU is an Intel Pentium Dual Core E5200 and I have two gigs of Crucial DDR2 533MHz SDRAM.
Should my PSU be able to support the Motherboard?
  • 1 more comment
  • Chopo87 Apr 24, 2009
    Hang on, Sorry I seam
    to have made a mess of my first post. I meant to post in response to
    another forum thread not start a new one.
    Anyway here are the
    symptoms. When I press the power button, the fans turn on, the CPU
    lode lights light up up the board. Normally, at this point, something
    cut's the power (I think Motherboard). Then the PC reboots.
    Sometimes, The PC gets as far as giving beep error messages. They
    differ, but once The error code was for the GPU and the other two was
    a general motherboard error. Other times the the pc can stay on for
    up to a minute before the power drops without giving any beeps, but
    still no post screens In these cases, If I plug in a DVD drive it's
    activity light seems to engage and if I plug in a hard drive, I think
    I can hear it spin (but case does not flash activity light). I've
    tested with VGA and DVI monitors.
    I've tested with just one
    and the other ram cards. But remember, The PC is not even posting. If
    it was the ram I should get a memory error POST, I think. I've tested
    the ram and GPU (Radion X800 SE) on another pc anyway.
    Can I
    measure the CPU temps If I can't access the BIOS?
    I'm almost certain It's
    a faulty Motherboard.
    When I have some time I
    will try the CPU on another pc and remove the board from the case to
    see if something is causing a short. Also, although the board
    doesn't officially support socket 775 pentium 4 CPUs, I tried
    swapping one in, In this case, the board would simply boot then drop
    power in about 1-3 seconds and go no further.
    Anything else I should
    try, or do I by this point have enough evidence pointing at the board
    to call up Gigabyte and request a new one?
  • Michael Slabbert
    Michael Slabbert May 11, 2010
    That PSU is fine for your setup. try taking out 1 ram and then boat. it is still does the same, try the same with the other ram. if it still continues, repost
  • Wim Sharpley
    Wim Sharpley May 11, 2010
    Have you checked youre C.P.U temp?
  • 87 Answers
I think you solved your own problem my friend... :)
but remember... if you put a cpu in that is not supported by the motherboard, you will break it.
Posted on Apr 24, 2009
  • 84 Answers
You need to replace the RAM ...
Why does my toshiba laptop turn off by itself. Doesn;t happen everytime
You can look at the computers event page in computer manager to find out what caused it to shut down. You click on start icon, then right click on computer and select manage. You will see event viewer listed on the left. It is generally caused by overheating. You might want to take a can of compressed air and blow out the laptops fans thoroughly to see if that helps. Laptops usually have a built in feature that forces the laptop to shut down if it exceeds safe operating temperatures for the processor.
Sep 23, 2014 | Toshiba Satellite Computers & Internet
Custom build PC shuts down by itself
you are overheating.did you use enough termic paste ? your computer shuts down for so it not breaks the processor.se to at allways as few startup programs as possible.and invest in a new PSU.
May 28, 2013 | Abit KT7A Motherboard
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
I have a HP Compaq DX2000MT computer. When I want to start up the pc, he gives 10 beeps and the following message : Chassis fan not functioning, check fan connections & call for service. Shutting...
Without the chassis fan the pc would overheat and fry so it's shut down. Do what the warning message says: open the case, clean the interior and check the wire connector of the fan. If the fan still doesn't turns then it has failed and it will have to be replaced - a new one costs$10 at every pc shop.
You will need the manuals for service and maintenance
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=401819
Aug 07, 2011 | HP Compaq dx2000 Microtower PC Desktop
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
Turns itself off & gets hot -don't think fan is kicking on
Since you do not hear the fan anymore I would start by opening up the case and seeing if power is going to the fan and make sure any connectors for it have not come loose. If the connectors are still hooked up chances are the fan is shot and needs to be replaced.
If you are not familiar with working around electronics and parts under power I would highly suggest you have some one who is familiar with this do it.
May 06, 2009 | Computers & Internet
The problem is with the switch mode power supply unit (SMPS). Use a compatible SMPS unit and your problem is sovled.
Mar 23, 2009 | Gigabyte Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Mar 13, 2009 | Computers & Internet
hi,
Please check for the exhaust,is it coming properly and check the bottom of the Notebook is it heating ?
If heating then this is the issue with the processor fan.
If the temprature is normal then check in BIOS(leave the system in BIOS mode for 8 minutes) if then also it is turning off surely this is the heating issue.
If above mentioned is not working please revert.
Feb 09, 2009 | HP Computers & Internet
Medion PC
From what I can tell is that the CPU fan is the problem. The CPU fan is probably what is whining right now, so if you want you can try and replace it. Also if it shuts down frequently, that's probably because the CPU fan isn't cooling your processor adequately, so the processor overheats, and the computer shuts itself down automatically.
Jul 27, 2008 | Computers & Internet
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
