Tromm dle977s not hot enough to dry clothes why and how do i fix it?
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V. First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2. Also check the connections and continuity for the heater element.
SOURCE: LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
SOURCE: I have a LG Tromm
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
SOURCE: My LG TROMM Dryer is not heating up and it takes
Hello & Welcome to FixYa If everything else in the dryer is working fine and it won't heat so it means that the thermal fuse which is located inside the rear panel on the blower wheel housing is bad and needs replacement. Please get back to me if you have any other questions.
