Question about Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Oven fan noisy/broken
The fan in the right-hand oven has started making a terrible noise when the oven is switched on. As this oven only works in fan-assisted mode, I can't use it. Can I buy a new fan and replace it myself, or is that a bad idea?
  • 5 more comments
  • jones34 Dec 07, 2007
    I have a GE oven with fan that has become incredibly noisy? I have no idea what to do.
  • Anonymous Jan 30, 2008
    I also have a very noisy fan in right oven. It is only 15 months old. Did you replace yours yourself or get rangemaster in?? Thanks Sarah
  • chester53 Mar 03, 2008
    Same problem - 18 month old rangemaster toledo 110 developed loud knocking/grinding noise in main oven and 2 weeks later the fan locked solid. Then within days the secondary oven also started making the same noise and within a couple of days that ceasep up too.
    New motors now on order at about £60 each plus VAT and fitting. I'm not sure if it's a DIY job to fit new fans.
    Whatever, it's a dissappointment that the oven has packed up so soon, suggesting a quality probems with these components.
  • cal186 Apr 29, 2008
    i have same problem with my rangemaster toledo after about 20 months one fan made a noise then the other now its redundant until we can find a solution to fix it. i took the back cover off but i'm not a cooker technician so didn't have a clue what to do.
  • Anonymous Jul 16, 2008
    when we turn on the oven the fan starts to make anoise and the fan stops working
  • john hayhurst Dec 30, 2008
    My rangemaster pro 90 has this problem, the fan is so noisy that I cannot bear to use the oven. Can a replacement fan be fitted by a diy type or does it need special tools to remove the fan motor. The actual oven is too heavy to move to investigate and I don't want to attempt it if it is not reasonably easy to fix.
  • Anonymous Mar 10, 2009
    yeah, my rangemaster 90 dual fuel stainless done the same , both ovens packed in after 15 months, wont touch rangemaster ever again
This noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Posted on Jan 12, 2008
  • 13 Answers
Rangemaster cookers come with a standard 2 year warranty so why have you people not been back to rangemaster for your in warranty repairs ??? By the way this was a massive batch of faulty fans that were sent to Rangemaster by a supplier, the supplier has promptly been dropped by Rangemaster (18 months ago) who now fit German EBM fans, some of the best in the business.
Posted on Nov 08, 2009
  • Bob Davis
    Bob Davis Jun 28, 2014
    Hi redstar 70, we have a Toledo 90 that has just started this issue, really noisy fan, we brought this in 2009, do you think we may have a case for rangemaster to replace this if they had faulty fans? Where did you get your information? Thanks Bob.
    New Friend:
My oven started to make a whirring noise, and now the fan doesn't work at all ?
Posted on Dec 08, 2013
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Mar 31, 2011 | Microwave Ovens
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Sep 27, 2010 | GE JKP15 Electric Single Oven
Fan makes a terrible rattling noise
The fan blade may have come loose from the shaft or the fan motor bearings are shot. Repair is accomplished by replacing the blade or motor. If the fan is not operating correctly the magnetron will star to overheat and the oven will shut down.
Jun 21, 2010 | GE Microwave Ovens
Noisy oven
Probably the fan bearing is worn out, looks like you will need a new fan.
Make sure there is not any obvious visual obstruction.
Jan 10, 2010 | Ovens
My smeg oven has a terrible noise in the fan on right hand side. My husband thinks the bearing has gone. As it stops quicker than the other fan.
It is going to be a worn bearing, or a loose or broken fan blade.
It more than likely means that you are going to have to replace the fan motor complete
One thing you can try is to spray the motor bearings with WD40, this may help to quiten it down
Hope this helps.
Dec 21, 2009 | Smeg Ovens
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Baumatic BT187ss Oven All working EXCEPT fan assisted cooking
I have a similar problem with my Zanussi and discovered there is a seperate element arounfd the fan wihich I think may be burnt out. Could be a similar fault have you investigated behind the panels in side the oven?
Mar 08, 2009 | Baumatic B180 Electric Single Oven
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Squealing oven
there is a separate casing fan hidden out of sight and this is what is squealing.
take oven out, remove top and back panel and you can see the casing fan. try wd40
Sep 17, 2008 | Neff B1641 Single circotherm super...
Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
6,328 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
