Philips DVP3680/F7 - 1080p Upscaling DVD Player with USB Link Logo
r
robert foster Posted on Oct 11, 2013
Philips 3680 front load its jam not open wide
3helpful
Code for philips dvd 3680
Try 12434 12205 12084 12056 11506 11389 11354 11340 11267 10675 10646 10539 10503
hope one works for you ..
1helpful
CD player door not opening
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Im looking for acer aspire 3680 ethernet drivers but what i get doesnt have executable file
load the driver to the desk top , then click open afterwards , if it is zip once downloaded extract it , then send to desktop then open it. hope that helps.
What are the two little button buttons in the front of my acer aspire3680 used for
...hmm,
Here is your manual (enter 3680 for the Aspire Laptop/Notebook):
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Those buttons should be your "open case" and then your 'wireless on/off' switch..but check your manual specifically for the 3680.
WW
2helpful
Paper Jam - HP G85 Ink Jet Printer
You open the door from the back of the printer (turn the knobs) and the paper can be removed from the back. After removing paper jam, replace the door. It is a long door as wide and the printer, but about 2 1/2" wide.
5helpful
2answers
FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Philips game trouble
When your game first loads. Enter the games settings and adjust the screen resoultion to match your wide screen monitor. If you can't get that far than hook up that other monitor. Load the game & enter it's screen settings (display) & adjust the resoultion. Your new monitor is wide screen. Your game needs to match the wide screen as well.
Good Luck!
Mike
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
