Question about Peg Perego Cub Cadet Tractor
Where can I get a manual for a peg perego cub cadet tractor
    Genius:
  • Peg Perego Master
  • 1,508 Answers
5 Suggested Answers
  • 670 Answers
SOURCE: peg perego cub cadet won't run
The gas pedal switch contacts get worn and so the toy will run for a few minutes then the stops. Replace the switch and you should be back in business. You can find the switch here http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
adamfjeld
  • 1508 Answers
SOURCE: do you know how i
you still need help with this?
Posted on Jun 06, 2012
adamfjeld
  • 1508 Answers
SOURCE: peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Sep 20, 2012
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego Cub Cadet Tractor W/Trailer wont charge or turn on !
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Dec 12, 2012
How to r/r a pto on cub cadet lawn tractor
Hi kenneldog60,
Can you please elaborate your question with the below details ?
  1. Confirmed model and make of your machine or lawn tractor.
  2. The problem that you are facing in clear language without any abbreviations.
  3. What else have you tried to solve the problem.
Waiting for your reply.
Jun 28, 2011 | Peg Perego Cub Cadet Tractor
Hello, I purchased this Peg Perego Cub Cadet Tractor and trailer almost 2 years ago and have run across a problem. One day it just stopped running. We charged it up as we usually do when the battery...
yes, very common. probably the thermal breaker under the shifter. you can replace it with a 40 amp fuse or bypass it. dont worry its safe to bypass b/c there is a 30 amp fuse on the battery also.
good luck!
Jan 19, 2011 | Peg Perego Cub Cadet Tractor
I have a cub cadet 2165, it was running great, turned it off-nothing happens when I try to start it, no clicking, nothing- checked battery cables-tight, checked for broken or loose wires-nothing-HELP
Hi
You blew a fuse. The easiest fuse to get to is under the hood and next to the gas tank. Replace it with the same fuse. Make sure the tractor is in neutral, blades are not engaged and the brakes are set. Should start right up. If not, you've blown a different fuse or a switch has gone bad. A reputable repair person is needed then.
May 20, 2010 | Peg Perego Cub Cadet Tractor
Peg perego cub cadet won't run. My little boy got off of it for a few minutes and when he got back on, it wouldn't work. We've had it about a year and it has been used almost every day. We just recently...
Dec 19, 2009 | Peg Perego 12 Volt Rechargeable Battery
Aug 19, 2009 | Peg Perego Cub Cadet Tractor
How do you put together the cub cadet trailer?
use the manual, if you need a copy of the manuala let me know
Jul 13, 2009 | Peg Perego Cub Cadet Tractor
Peg Perego Cub Cadet Tractor Logo
126 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
