I have a Bryant Ductless Cassette that the condensate pump motor locked up. I am having trouble finding a part #.
  • mark_satterl Apr 23, 2009
    It is an internal motor and pump assembly not an extrenal gravity fed.
    Problem Solver:
  • 19 Answers
Just replace your condensat pump. any local hardware store should have condensate pumps. just tell them what your application is for and they should be able to give you the right pump.
Posted on Apr 23, 2009
My Bryant air handler with V coil is dripping condensation outside of drain pan and onto my return plenum. I have to keep a bowl to collect the condensation. Pan not clogged and refrigerant ok. Con
Either the coil pan is cracked, or the coils are not set properly. if coil pan is cracked, you have two options, Replace the coil, or get a condensate pump. The condesate pump is a temporary fix because some water would stay in the secondary pan and eventually rust it out, causing damage to whatever is below it, which is usually your ceiling.
Apr 08, 2014 | Bryant Heating & Cooling
Bryant condenser not running.
Check that there's power available (open or tripped breaker or disconnect). If there's power available, check for 24-28 volts feeding the contactor coil. The low refrigerant cut-out may have tripped the 24v (leak). The pressure cut-out may have tripped (dirty condenser coil, inoperable condenser fan motor). If there's 24 volts at the contactor coil, check the capacitor before ohming the motor. A defective run capacitor will shut the compressor down.
Aug 27, 2013 | Bryant Legacy 16 Series 4.0 ton AC...
I am trouble shooting a Bryant Hi-bred system that uses an air cooled heat pump with high efficiency gas furnace for backup and low ambient operation. How does the system decide whether to use the air...
Your t-stat should be set up so that the furnace is the second stage heat and also emergency heat. First stage (heat Pump comes on) sometimes they use Time to start 2nd stage, sometimes they use outdoor temp and this all bepends how bryant has set it up, without a model # I cannot tell you but send it and i will look in somebooks i have to tell you.
Mar 01, 2011 | Bryant Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
Compresser is not running
The condenser fan motor is most likely blown. A replacement fan motor and a run capacitor are most likely needed to get it back in working order.
Jun 01, 2009 | Bryant Heating & Cooling
Bryant a/c heat pump "model 540bj024"
Check if you have 24volt out of the board if not replace it.
Feb 22, 2009 | Bryant 463AAC008BA Air Conditioner
Bryant a/c heat pump "model540bj024"
I have to start with the wire diagram. Find the circut board. Look for any connections marked to the thermostat and follow to what they go to. See what other controls it has pressure sw, tenp sw, ,,, then decide how its suppose to work.
This may not help you but it is a direct answer to your request. If you need more infor I need more info and spicific  on what you want to check.
IF THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK.
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
