Question about Garden
Kicks back when chord is pulled to start
Self propelled lawnmower Partner 471S. Was working satisfactorily yesterday, but today , it kicks back with terrible force as if the sto is still engaged.The brake cable appears to move freely backward and forward. What is causing this?
  • mahmoodjamal Apr 24, 2009
    Thanks a lot COUGHY_MAN. You've hit the nail on the head. The flywheel key was sheared.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
The main reason for the kickback is the flywheel key is sheared, and must be replaced
Posted on Apr 24, 2009
I have a Snapper self-propelled lawnmower and The starter cord will not pull out to get it started. What do I do next?
Hi Patricia,
There is probably a safety lever that has to be pulled back toward the handle in order to release the flywheel. (This lever is on the top side of handle.) Once you have it firmly against the handle it should start. To stop the mower, simply release the lever. There may also be a 2nd lever to engage the self-propelled (located under the handle). It may be difficult to start with this one pulled.
Jim
May 23, 2016 | Briggs & Stratton Garden
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I have a troybilt self propelled model series 830. Yesterday we hit a stump and the blade bent and shut the lawnmower off. I recranked it and tried to recut when i noticed the blade was bent so i took it...
the blade is bent,replace it or you will ruin the engine,a new blade is much cheaper than a re-built engine and bearings,you bent it soooooo bad you can no longer even balance it, and if you continue it will destroy the engine if you have not done so already,this is the vibration you feel NOW
Jul 29, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Will not start
completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
Aug 27, 2009 | Garden
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
308 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
